Myford tumbler gear.
Home Forums Manual machine tools Myford tumbler gear.
  • #156589
    rebekah anderson
      @rebekahanderson95322
      Hiya,
      im looking for an 18tooth tufnol tumbler gear.
      I've seen some on eBay but wondered if there are better deals as I need 2 of them.
      rebekah anderson
        #156616
        JohnF
          @johnf59703
          Hi I looked on EBay. and they are less expensive on the Myford site see http://www.myford.co.uk/acatalog/Myford_Gears.html
          Looks like the eBay ones are loaded to give free postage !
          Regards John
          #156617
          John Stevenson 1
            @johnstevenson1
            Those red ones off Ebay are the wrong type of material, you might as well use putty.
            Are those 7/16" bore Becky ?
            #156636
            stan pearson 1
              @stanpearson1
              Hi Rebekah
              John is correct buy the ones from Myford they are cheaper and fit no problems, I have just fitted 2 new ones to my Super7,
              Stan
              #156654
              Swarf, Mostly!
                @swarfmostly
                Hi there, Rebekah,
                Are you sure you need two-off? The parts list on the Mytholmroyd-Myford web-site specifies one-off 18 tooth, 75/1241 and one-off 20 tooth, 75/1242, (per lathe).
                Best regards,
                Swarf, Mostly!
                #156656
                John Stevenson 1
                  @johnstevenson1
                  Swarf, Only Becky can answer this one as her lathe is a much modified ML4 and I dare say nothing is standard.
                  #156668
                  rebekah anderson
                    Good question.
                    i didn't consider there to be a difference. I only kept one. Oh crapola.
                    guess I'll find out.
                    Cheers guys
                    becky
                    #156693
                    Swarf, Mostly!
                      @swarfmostly
                      Hi there, Rebekah & JS,
                      Oops!!! My mistake!!!
                      The part numbers I quoted in my earlier post are for the steel gears that the Tufnol ones replace.
                      The part numbers Mytholmroyd-Myford quote for the Tufnol gears are:
                      A1781, (B36, Reference Number 498), 18 teeth, £17.68 + VAT.,
                      A1782, (B35, Reference Number 499), 20 teeth, £17.68 + VAT.,
                      All the tumbler reverse set-ups I have encountered use two non-identical gears (idlers).
                      Regarding your point, John, I guess that can only be resolved by a comparison of the gear centre distances and spindle diameters on the ML4 and ML7.
                      Best regards,
                      Swarf, Mostly!
                      #156699
                      John McNamara
                        @johnmcnamara74883
                        My old (Very) change gear Colchester had different size gears…. Is it not to do with allowing them to clear the spindle gear when being rotated?
                          probably, on my mini-lathe the large gear is in permanent mesh and the smaller gear is 'free'.
                          John Stevenson 1
                            @johnstevenson1
                            Swarf, Be hard to say what they are because if I remember the thread correctly Beckys machine as posted had been seriously updated so might have a ML4 tumbler on it or a ML7 tumbler on it.
                            This is Becky's lathe but the tumbler isn't that clear.
                            With the alloy extension piece it looks more like a pimped up ML4 as opposed to the stubby acorn ML7.
                            Would be nice to know what bore they are.
                            #156747
                            Bubble
                              @bubble
                              Hello all
                              Tony Griffiths' site has a photo of an ML4 fitted with an ML7 tumbler reverse, including the reverse lever/gear carrier.
                              Jim
