Myford thread dial bolt size
Home Forums Workshop Tools and Tooling Myford thread dial bolt size
Viewing 25 posts - 1 through 25 (of 28 total)
  • #289053
    Allan B
      @allanb
      I have just bought myself a thread gauge to add to my Myford, but dose anyone know what the thread is in the right hand side of the carriage? It doesn’t come with the bolt, but I’m not to good with imperial bolt sizing and I would like to make a knurled thumb bolt ready to fit.
      Thanks in advance
      Allan
      Allan B
        @allanb
        #289055
        Jon Gibbs
          @jongibbs59756
          Hi Allan,
          The thread is 1/4" BSF but mine is a stud and nut.
          HTH
          Jon
          #289057
          roy entwistle
            @royentwistle24699
            So is mine
            Roy
            #289061
            Nigel Bennett
              @nigelbennett69913
              Allan – it doesn't just bolt straight on to the apron; Myford provide a couple of red fibre washers to space the unit off the apron in order to get the graduations to line up properly with the fiducial mark when the half-nuts are engaged. You need to fiddle about and choose the correct thickness combination of washers to do that.
              As Roy & Jon have said, it's 1/4"BSF.
              #289063
              Allan B
                @allanb
                Thanks all, love how much information is on this forum.
                I will have a look for a stud and a tap so I can make a thumb whee, I have got numerous washers I can use to get a size, then a bit of nylon I can make a spacer out of as a final fix.
                Allan
                #289067
                Jon Gibbs
                  @jongibbs59756
                  Posted by Nigel Bennett on 16/03/2017 08:39:21:
                  ….Ahhh, that would explain why mine doesn't line up exactly when engaged then – I have no fibre washers on mine.
                  Thanks Nigel.
                  Jon
                  #289069
                  Allan B
                    @allanb
                    Now this might be sacrilegious but would an M6 stud do the same job (me penny pinching as normal with what I have in stock lol
                    1/4bsf is 6.35mm but it’s always cut a little under for threading so say 6.25mm,it is a 26tpi which comes out as 0.977mm, which is almost an M6X1 stud size, the only thing u would wonder is how much force it needs to take as it would only be holding by 3/4 of the thread area.
                    Allan
                    #289072
                    Brian Oldford
                      @brianoldford70365
                      #289075
                      Jon Gibbs
                        @jongibbs59756
                        Allan,
                        Well if you're wanting to get into threading (otherwise why else would you want the threading dial on?) then why not turn a bit of the lathe?
                        The stud is plane 1/4" under the dial body rather than threaded – less wear over time although most of the time it'll stay put I know.
                        1/4" BSF is 26 TPI and you can leave the half-nuts engaged and reverse the tool out as you'd have to do for metric threads to avoid the threading dial issue.
                        If you need a 1/4 BSF nut to test fit then borrow one from elsewhere on the lathe. The banjo uses two of them and you could manage without one for a moment or two.
                        HTH
                        Jon
                        Edited By Jon Gibbs on 16/03/2017 09:38:48
                        #289078
                        Jon Gibbs
                          @jongibbs59756
                          You could always buy a die **LINK** or **LINK**
                          The Chronos price is delivered.
                          Jon
                          #289081
                          Allan B
                            @allanb
                            OK I have bitten the bullet and bought some BSF nuts and will make the stud to match them, have got some HSS I can grind to the specified 55 degrees.
                            Allan
                            #289089
                            not done it yet
                              @notdoneityet
                              There are so many options – as long as the thread into the casting fits. Threaded rod, bolt (not favourite), a stud with any thread you choose on the other end, metric, imperial, cycle? Nut, thumbwheel, wing nut. Any combination with the other end 1/4 BSF!
                              The usual reasoning with studs into cast is coarse in the cast end and (possibly) a finer thread for the nut. With a finer thread the nut gets undone and not the stud and is better for high clamping force applications. This is not a high clamping force application, of course. Think cylinder heads for high clamping force requirement.
                              Threads wear over time with continued use. The stud is easier to replace than the threads in the casting. Remember also that the thread dial has a clearance hole (for the relevant sized stud). Fitting a smaller stud should not be contemplated, even though you 'might get away with it'.
                              #289090
                              Allan B
                                @allanb
                                OK so if I am going to do this properly, and before the actual part arrives, could someone please measure how long the hole through the the tread gauge is, and also what the ID is, then I will make a stud with 1/4 BSF on one end, M6 on the other, and then a thumb wheel to match
                                Allan
                                #289093
                                Jon Gibbs
                                  @jongibbs59756
                                  Here's my stud in situ. The stud is exactly 0.250" in diameter (calipers below). You should be able to tell how deep the threaded hole is on your apron perhaps.
                                  Jon
                                  #289094
                                  Jon Gibbs
                                    @jongibbs59756
                                    Posted by Jon Gibbs on 16/03/2017 11:12:45:
                                    Link to original image here… **LINK**
                                    Jon
                                    #289095
                                    Allan B
                                      @allanb
                                      Jon
                                      Thank you for that, I now know what tonight’s job is 😀
                                      Allan
                                      #289096
                                      Jon Gibbs
                                        @jongibbs59756
                                        Happy turning! yes
                                        Edit: When I think about it, it'd be really strange if the stud wasn't symmetrical end-for-end so that ought to give you everything you need.
                                        Jon
                                        Edited By Jon Gibbs on 16/03/2017 11:20:01
                                        #289102
                                        Harry Wilkes
                                          @harrywilkes58467
                                          Thanks for the info Nigel I was not aware that you needed to adjust the fibre washers, when I acquired my S7 in came with a thread gauge but it was not fitted so I'll check it out.
                                          H
                                          #289120
                                          roy entwistle
                                            @royentwistle24699
                                            I always thought that the fibre washers were so that it could be engaged and disengaged without using a spanner
                                            Roy
                                            #290073
                                            Jon Gibbs
                                              @jongibbs59756
                                              I think Roy is more likely to be right than Nigel, now that I've examined my threading dial in more detail.
                                              The pinion is free to rotate and is held simply with a cap-screw and washer onto the bottom of the indicator shaft. So, it can be positioned anywhere to adjust its position, irrespecitive of any fibre washers.
                                              I think you just need to engage the half-nuts, mesh the pinion, align the indicator with the witness mark and snug up the cap-screw from below?
                                              Jon
                                              #290100
                                              Richard S2
                                                @richards2
                                                Posted by Jon Gibbs on 22/03/2017 17:31:39:
                                                I think Roy is more likely to be right than Nigel, now that I've examined my threading dial in more detail. Jon
                                                Seems both can be right !. Myford ML7 Manual mentions the Fibre Washers are provided for alignment of the Dial markings with the zero mark on the Indicator Body (page 28, fig 39).
                                                They (washers) can also serve to provide suitable resistance to permit engaging and disengaging of the indicator with the Leadscrew by hand pressure as many have found to be a handy procedure, but is not mentioned in the Manual.
                                                #290158
                                                Jon Gibbs
                                                  @jongibbs59756
                                                  Thanks for the reference to the figure in the manual – I obviously don't know that manual as well as I should.
                                                  When I look at other indicators on ebay they clearly don't have a capscrew holding the pinion gear on, which would obviously change the adjustment possibilities dramatically.
                                                  and
                                                  I am therefore beginning to wonder whether my thread dial indicator is either an old one or has been modified because it still seems to me to be much easier to align things by adjusting the retaining screw than trial-and-error with fibre washers that will compress over time. To boot, mine is also missing any fibre washers.
                                                  Jon
                                                  #290164
                                                  Brian Oldford
                                                    @brianoldford70365
                                                    Posted by Richard S2 on 22/03/2017 19:57:41:
                                                    I'm happy to be proven wrong but I've never seen a need to disengage the indicator from the lead-screw. Surely any increased wear is going to be immeasurable?
                                                    #290179
                                                    Philip Rowe
                                                      @philiprowe13116
                                                      I also never disengage mine, apart from the rare occasions when removing for cleaning/maintenance my thread dial has been permanantly engaged since 1973 and I can't detect any wear.
                                                      Phil
