Toothed timing belts run the risk of a cogging effect resulting in finish issues on your parts
Modern timing belts run smoothly. If that were not the case, many (if not most) of the worlds CNC machines would have surface finish issues from the axis drives, as timing belts are the most popular way of connecting servo motors to ballscrews.
A bigger issue with high speed timing belt drives is noise, generated by air getting trapped between the belt teeth & the pulley grooves. This is more of an issue with wider belts & one recommendation is to use multiple narrow belts on a wide pulley to allow the air to escape more easily. One of my former colleagues used a wide timing belt on a milling machine spindle drive. The motor was around 15Kw, so the belt was quite wide & large pitch. The noise was horrendous – like being stood next to an air raid siren & ear defenders were a must while operating it. The customer was not happy but, fortunately, the drive had been designed around standard Taper lock pulleys & replacing the timing belt solution with 3 groove B section vee belts transmitted the required power in near silence.
I have not had good experiences with Poly vee drives. Higher power than model engineer size machines admittedly, & only chosen due to the theoretical ability to transmit the required power at short centre distances, but the belts wore out in short order. Moulded cog raw edge wedge belts would be my choice here.
Could be fun trying to unscrew a Super 7 chuck after putting a 1.1Kw load though it.
Nigel B.
Edited By mgnbuk on 28/03/2020 10:58:42
