Myford S7 Spindle Nose / Chuck fitting.
Home Forums Manual machine tools Myford S7 Spindle Nose / Chuck fitting.
Viewing 10 posts - 26 through 35 (of 35 total)
  • #107258
    Chris Trice
      @christrice43267
      Any crud in the thread probably does throw off cocentricity quite a bit. The register is their to limit its effects but then crud on a taper mount does the same thing.
      blowlamp
        @blowlamp
        A chuck etc, can only be restrained radially (by design) by either the thread or the cylindrical part of the register, but not both at the same time or interchangably – it's got to be one or the other. Lathes made without registers were just designed that way and weren't intended for really accurate work, why else would any manufacturer bother with registers? Martin.
        #107262
        Tony Pratt 1
          @tonypratt1
          Of course a threaded only spindle will and does work but I would imagine was only chosen for cheapness. We then move up to parallel register/thread and then the most expensive but prefered option is tapered register and either a screw or cam locking system, I'm sure if a thread only spindle was acceptable the large machine manufacturers would not spend a fortune making the fancy tapered location varieties?
          Tony
          #107263
          Tony Pratt 1
            @tonypratt1
            Blowlamp, just read your post. Another principle I picked up along the way is that you do not need two registers to do the same thing and is incorrect and adds extra cost .
            Tony
            #107264
            John Stevenson 1
              @johnstevenson1
              I think you are forgetting that the large machine manufacturers sometimes need reverse, although the Harrison L5 and the early Colchester master had screw on / fly off spindles.
              #107265
              blowlamp
                @blowlamp
                Posted by Tony Pratt 1 on 27/12/2012 15:28:00:
                Tony
                I think that's called a 'redundant constraint'. Martin.
                #107266
                John Stevenson 1
                  @johnstevenson1
                  Ok so will will do away with the register like the early machines..
                  We know this works.
                  Now we will do away with the thread and just keep the register. OOps – clunk
                  So this proves emphatically we need the thread but not necessarily the register ?
                  John S.
                  #107270
                  Chris Trice
                    @christrice43267
                    Tony, a thread is all that’s needed but the register is there as an additional safeguard to limit eccentricity. It can only centralise a chuck to the limits of the clearance between register and backplate. If modellers could be trusted to keep the threads of both chuck and spindle spotlessly clean, the chuck would always find the same fitted position each time in the same way that a centre and centre drilled hole will without the need for a register. Only a spindle with a taper mount, also kept spotlessly clean will automatically and actively centralise a chuck to its exact concentric position. Any tube containing a shaft can only hold the shaft within the boundaries of its bore to the limits of the clearance between them.
                    Edited By Chris Trice on 27/12/2012 16:22:09
                    #107271
                    Sub Mandrel
                      @submandrel
                      It must be Christmas! I can see angels dancing on the lathe spindle nose – now haow many are there?
                      Unless you have a camlock or stud fixing… and are inherently superior IMHO
                      Bazyle
                        @bazyle
                        Seen a thread on another forum where there was a problem with a camlock that was bottoming out on the flat rear face (not sure what to call that) before the taper had made full contact. A problem of poor manufacturing tolerance of course which is where this thread started.
