Myford ML4 Threads
Myford ML4 Threads
Home Forums Manual machine tools Myford ML4 Threads
Viewing 10 posts - 26 through 35 (of 35 total)
  • #302440
    Bazyle
      @bazyle
      Posted by Speedy Builder5 on 13/06/2017 16:00:31:
      I have read the FORUM notes on BA threads, but it must be a pain to set your lathe up for screw cutting BA, being neither TPI nor any common metric pitch. Were / are special lathes made specifically for BA threads?
      BobH
      Before everyone became rich enough to think of a screwcuttign gearbox as being the norm even production lathes used changewheels. So setting up for BA wasn't much different to anything else.
        Posted by John Flack on 13/06/2017 16:02:12:
        Following Michael Gs full title of the BA, I wonder if any body could name any other of their activites???????????
        How about Evolution, the Volt, the Ohm and the Ampere?
        These days BSA aren't quite so leading edge but they remain the UK's chief promoters of science and technology in support of industry. Sadly they've always been resisted by the 'old ways are the best' crowd, and more recently by chaps who think it's more important to be in touch with feelings than it is to bother with facts.
          Try putting "british association for the advancement of science" [with the quote marks] in the search box for any decent library.
          This one being my favourite: **LINK**
          http://www.library.manchester.ac.uk/search-resources/
          ega
            @ega
            Lehman Archer and B.A. Taps:
            I enjoyed the article, particularly as it is based on original materal.
            The quotation from the LA catalogue gives the BA thread angle as 47 degrees; I had always understood it to be 47.5 and wonder whether this is a typo or, perhaps, there was a further change to the specification.
            BA threads have metric pitches and it is interesting to see that the catalogue also gives a TPI equivalent. On the accuracy point, I would have thought that introducing a 127T gear would have allowed theoretical perfection. Is the "correct to within 1/53,300th" a reflection of the then state of the relationship between inch measure and metric? I believe it is only relatively recently that the 1" = 25.4mm equivalence was settled.
            #302526
            John Flack
              @johnflack59079
              To those who responded to the question I posed earlier I was asking who could "name" their activites NOT WHO IS GOOD AT LOOKING THINGS UP. If you answered from memory well done, but I assume that you are in a select minority
              On a slightly different thread(?) I have always thought that the BA thread was more pleasing to the eye as were certain threads in the ME range
              On the question of screwcutting perhaps given their age and the types of lathes available they were never intended for that purpose, hand use or specialist eg watchmaking eqpt. was envisaged
              For those not conversant with BA certain of the odd number threads matched the Imperial rod size that was available in times past. LBSC made good use of this fact
                Posted by John Flack on 14/06/2017 12:48:09:
                John,
                I'm not really sure if your "shouting" was directed at me dont know
                Hopefully not, as I simply directed you to the wealth of information that is available.
                … as you will see, it's a long list.
                If you were "setting a test" then be assured that I have no intention of sitting it.
                P.S. For info. … The reason that UoM Library is my favourite point of reference is that I use the Elsevier Reading Room at John Rylands most Thursday afternoons. http://www.library.manchester.ac.uk/rylands/
                Edited By Michael Gilligan on 14/06/2017 13:08:25
                #302544
                John Flack
                  @johnflack59079
                  MichaeiG sir…..I neither shout or display bad manners my nanny was very strict on such matters.
                  I was suggesting that a majority may know nothing about the Association beyond taps and dies
                  If my comments have given offence may I offer my apologies and be assured that I will try to prevent such occurrences in the future
                    Posted by John Flack on 14/06/2017 16:44:42:
                    John,
                    If you care to research "netiquette", you will find that the use of upper-case text is generally construed as "shouting".
                    Aside from that though … your gracious apology is accepted and reciprocated.
                      As it happens, I find the interaction between science and technology fascinating and have long known of them. Nothing wrong with being good at looking things up either: it's a valuable skill.
                      But I think you're making a different point. You're absolutely right to question if the BSA has the public's attention. I'd say they aren't as well known as they should be, particularly as they're meant to be banging the drum.
                      John Flack
                        @johnflack59079
                        Sod …..thank you that's the point I was making.
                        I once attended a conference where the Publicity Officer was receiving a lot of "stick" unable to control his anger he grabbed the microphone and shouted "there's a lot of publicity going on that nobody knows about". That sort of sums up my knowledge of the British Association🙄
