Myford ML2 Drive
Myford ML2 Drive
Home Forums Workshop Tools and Tooling Myford ML2 Drive
  • #350755
    Paul Bishop 4
      @paulbishop4
      Evening everybody. Bought an ML2 to restore. Not too bad condition. Has flat belt drive on spindle. I've bought a second hand 3 phase motor which I'm going to put a vsd on. As flat belt pulleys are like hens teeth, what are your thoughts on using an A type V pulley and a 12mm Fenner power flex type belt on the centre of the spindle flat pulley? I know its not an ideal solution but considering the fastest speed recommended for the ML2, I think it would be ok. Searched and searched but nothing I can find. Thanks for any responses in anticipation.
      Edited By Paul Bishop 4 on 19/04/2018 19:10:53
      Paul Bishop 4
        @paulbishop4
        #350756
        John Rudd
          @johnrudd16576
          So why not make your own flat belt pulley? Cast iron or aluminium…..
          Assuming you have access to another lathe…
          #350763
          Paul Bishop 4
            @paulbishop4
            I would John if A) I was skilled enough B) If my other lathe had a big enough chuck. Was hoping my fix would suffice until I managed to source either the motor pulley, or the v belt pulley for the spindle
            #350764
            Georgineer
              @georgineer
              Vee-flat drives using a conventional V-belt are an accepted way of driving – my ML4 has a flat countershaft pulley and a vee pulley on the motor, and it has worked without problems for nearly 50 years. However, I suspect that using a cogged belt like the Powerflex would cause vibration issues as the cogs make contact with the surface of the flat pulley.
              George
              #350768
              Paul Bishop 4
                @paulbishop4
                Maybe I'll try a normal v belt first. Do you notice much wear on the belt?
                #350794
                  I would put a poly-vee pulley on the motor, and let the poly-vee belt drive the flat pulley on the lathe.
                  … It has worked for me in the past, and is common practice on washing machines & tumble driers.
                  [yes, I know; the diameter, and therefore the length of wrap, is much greater on the domestic appliances]
                  #350797
                  Hopper
                    @hopper
                    +1 on Michael G's suggestion for Poly V belt running on flat pulley. I replaced the flat belt on my old Drummond M-type, similar machine to the ML2, with a poly V belt and it runs on the old flat pulleys very, very well. No slippage problem at all. You can probably get a poly v pulley from a car wreckers' yard off a car air con compressor etc that could be adapted. Or just turn one up from ally.
                    #350814
                    Martin Johnson 1
                      @martinjohnson1
                      Back in the day (about 50 years now) I had an ML2 driven direct from a 1450 rpm motor by flat belt onto the headstock. Absolutely dire!
                      I built a countershaft unit hinged at the back of the bed with motor hanging off the rear, V belt drive up to countershaft. I modified the lathe to V belt pulleys by turning the cast iron flat belt pulleys off to leave a parallel sleeve, then loctited a multi step picador pulley onto the remaining sleeve. It worked OK. I later grafted a clutch onto the countershaft which saved a lot of motor stop / starting.
                      If I was doing the job today, I would use Poly V belts, J section, you would only need 4 groove pulleys and they could easily be turned into the existing cast iron pulley. You will need to beg / borrow / steal another lathe to the turning though.
                      A little warning – my ML2 had the cross slide feed screw graduated at 80 thou., but the screw was actually 12 tpi giving 83 thou advance per turn. This caused quite a few scrappers until I worked out what was happening and made a 12.5 TPI screw and tap. In hindsight, I should have made it 20 TPI, and re-made the micrometer collar with 50 divisions.
                      Hope that helps.
                      Martin
                      #350964
                      Paul Bishop 4
                        @paulbishop4
                        Thanks Martin. I've now ended up with 2 ML2's, so going to experiment. I have a (shock horror) chinese lathe so should be able to make parts on that for now for the ML2.
                        I'd like to put a countershaft system on. I have to see if I can attach to the lathe, or else mount behind the lathe. Fun to be had. Solution challenges come to mind.
                        #350975
                        Brian Wood
                          @brianwood45127
                          Martin,
                          The 12 TPI tool slide feed screws were also a feature on the ML4 lathes, Myford in their wisdom at the time thought that was 'close enough' for most work; I quote from the handbook issued with the lathes.
