Well done!
One thing to look at when comparing these two lathes is the width of the bed ways in comparison to the centre height.
The Myford has a 3-1/2" centre height above the bed, and the bed ways width is 4-1/2". So the triangle between the bed ways and spindle is wider than it is high. This gives good stability for the carriage and cross-slide through to the cutting tip.
Some Chinese lathes I have looked at seem to be the other way round. The bed is narrower than the centre height. This results in the opposite, a triangle that is higher than it is wide, and thus inherently relatively unstable. That is why some Chinese lathes tend to look as if the cross slide and top slide are artificially perched up a bit higher than necessary. But it does give them that extra swing they like to emphasize in the sales brochures.
Would be interested to know the WM180 bed width in comparison. The added rigidity of the bigger Myford is not just due to mass but also this design feature perhaps.
And it's not just a pet theory of mine. One of the design criteria for top-line toolroom lathes is that the bed is wider than the centre height. They tend to go to the opposite extreme, the chuck looks like they mounted it an inch or two lower than they could have done.
Look forward to hearing your thoughts as you "acclimatize" yourself to the new machine.
