Mounting work
Mounting work
Home › Forums › Beginners questions › Mounting work
  • #8390
    Brian Hoare
      @brianhoare64137
      Stuart Model 9
      #266732
      Brian Hoare
        @brianhoare64137
        I have a sieg sc2 lathe with a vertical post and a sieg sx2 Mill and I have difficulty in mounting the soleplate to be able to machine the 1.5" dia hole and to face the flange either using the lathe and vertical post or the mill.
        The vertical post attachment faces the chuck. I could fix the soleplate to an angle iron but I am at a loss to see how I can mount this on the lathe or mill.
        #266742
          I'm not sure how the topslide fixes to the cross slide on your machine but if there are some holes in the cross slide you can use these to mount the casting with suitable packing between to bring it upto center height. The hole can then be bored with a simple home made between centers boring bar and a flycutter used to face the cylinder mounting flange at the same setting to keep things true and square.
          Another alternative would be to rotate the vertical slide through 90degrees if you can and then hold the base of the casting against the slide. Machine as above.
          How much room is there between mill taple and the spindle nose, another option would be to mount casting with flange facing upwards on the mill with an angle plate and use a boring head to do the hole and flycut the flange.
          J
