Motor repairs
Motor repairs
Home Forums General Questions Motor repairs
  • #492910
    Phil Boyland
      @philboyland37326
      Hi, can anyone recommend a motor overhaul place in the Derby area.
      My lathe motor has developed an issue so need to get it looked at.
      It’s a Tyco Crompton one for a Super7. When running it now makes a vibrating sound, although can’t physically feel any vibration and sometimes it does not spin at all, just buzzes. It’s getting upto speed no problem, just very annoying to use it in this state. Guessing bearings are gone but I’m far from expert on things like this.
      Cheers
      Phil
      Phil Boyland
        @philboyland37326
        #492912
        Hopper
          @hopper
          Changing the bea rings yourself is a very easy job and will save you a lot of money over getting it done. They would have to be pretty bad to stop the motor turning altogether though. Could be a problem with start windings and associated switch or capacitor. In which case things get more complicated but not beyond the scope of the home workshop.
          Easiest way to check the bearings is to take the belt off and spin the motor pulley by hand. Should feel nice and smooth with no lumpiness or binding.
          Edited By Hopper on 27/08/2020 09:56:46
          #492913
          Dave Daniels
            @davedaniels93256
            Posted by Phil Boyland on 27/08/2020 09:33:58:
            Cheers
            Phil
            Bowers Electrical Heanor ??
            You could try them but they are at the 'big stuff' end of the trade.
            Could well be cheaper to get a new motor.
            Used to use a firm in ( Shaftesbury St. ? ) but I think they're long gone.
            Brian Wood
              @brianwood45127
              Hello Phil,
              It is many years now since I was based in Derby but a Google search produced the following:-
              Long Eaton Rewinds Ltd, Unit 3 Langham Park, Stanton-by-Dale DE7 4RJ Phone 01332 873118
              I have no knowledge of the organisation whatsoever, you are on your own with that
              Your fault description sounds like a start capacitor failure if your motor is fitted with one, they usually live in the round bulge on the outside of the motor. It is either that or the starter switch built into the motor which now has dirty contacts. The least likely fault is a winding failure
              It will mean taking the motor apart to clean the switch, the capacitor would be a simple replacement part. If you are unhappy with that sort of work any competent sparkie will do it for you and test the windings.
              Regards Brian
              Edited By Brian Wood on 27/08/2020 10:18:22
              #492962
              Howard Lewis
                @howardlewis46836
                +1 for Brian's suggestions of either a failed Start Capacitor, or a faulty centrifugal switch.
                #493036
                Phil Boyland
                  @philboyland37326
                  Ok that’s great cheers for the info. I’ll have a go myself first,
                  best regards
                  phil
