The lathe is a 1950 model and the stand/cab is from this period I think, looks like a Myford stand to me, it has a Santon reversing switch mounted central in a screw cutting tables. The stand has four substantial tabs , one at each corner drilled approx 1/2" .A previous owner had fitted a 6" wooden extension round the suds tray.
Good point about checking the working height, the old Colchester student i used at work was a good bit higher.
i have some 4" x2" African teak battens which I could use for packers, or maybe a trip to the local smiddy for a couple of RSJs. Cross slide at navel is a good point to shoot for,cheers for that.
Clean slate at the moment so all tips considered, the local recycling place had some decent floor tiles in, i may smarten up the plinth with them to make sweeping up easier.
The lathe and stand came without raising blocks, I have obtained a pair, but they are tapped 5/16 BSF where the lathe bed mounts, no adjusters so it will need shimms to level, I have some brass shim stock to hand for this.
Thanks to all.
