Posted by Mark Muller 1 on 30/05/2018 20:23:51:
So… not sure if all my replies were read, but you know what, I'm going to shop for 500W motor. I'll use the 3hp for a table saw or something… don't lecture me, I know about table saws!!
I'm upgrading to tapered roller bearings anyway (and "slippable" belts), but to keep the peace, I'll go for a lower wattage motor. I still think it would've been fine (yes, I'm a newbie, but I'm also not daft!), but life's too short and I'll just get the darned little motor. Thanks again everyone. M
Hi Mark,
Now that everyone understands what you have got, along with an idea of your ability, do consider the various options proposed.
If you are considering Neils route, then do consider a higher wattage motor around 1hp+ route, with appropriate VFD, rather than the 500W motor route, especially as it is not clear if the 500W is 'input' or 'output'. This is relevant because thereafter, you have to consider the torque issues – VFD programing. If you have more power to work with, this can be de-rated via the combination of programming as well as mechanical. If you start with 500W, you may get issues with 'not enough torque' at various points in the speed range. This will be a process of experimentation. I don't know if your original 3hp/2.2Kw idea will or will not be appropriate/suitable for de-rating, or if Neils/Steves routes are the directions. This is up to you to consider, based on your abilities, now that we know what we are dealing with.
For the bearings, in your case, do consider angular contact (AC) bearings in place of taper roller bearings (TRB), as the mechanical torque on the TRB will result in transfer of a slightly higher load onto the motor, i.e. the motor will need to work slightly harder to turn/drive the spindle. Reason: Based on the pre-load on bearings, in AC bearings (7206B-2RS) the balls have a two point contact on the insides of the inner and outer race, where as for TRB – 30206 (for example), the rollers insider the TRB have full contact with the insides of the inner and outer race. The difference in accuracy between the two types of bearings is so marginal when used in a mini-lathe that it is not necessary to consider a TRB, and the use of AC bearings can deliver marginally higher speeds, which is great for getting better finish with the right tools, on non-ferrus material.
Ketan at ARC.
