Hi All,
I realy should not be allowed near anything electrical!
I have a power X axis feed on my Warco 18 Mill which I got in a clearance from Axminster a while ago, made the bracket etc and installed it. Worked just fine and tranformed the machine into something a pleasure to use.
I did not need and did not fit the Limit Switch unit and just coiled it out of the way.
After a while there was an intermittent fault where the feed would only work one way and not the other. This turned out to be a dry joint in the limit switch box which was fixed by giving it a 'wiggle'. Worked for ages after that.
I removed the small switch buttons to stop them accidentally getting knocked.
Yesterday I was using the mill all morning just fine, then dropped something and jarred the limit switch which brought the fault back so thought I would fix it once and for all and resolder the joint properly.
STUPIDLY I did this wihile the mill was still connected to the mains! Small puff of smoke from the joint , fuse in unit blown, me VERY angry.
Changed the fuse but now nothing works at all on the feed unit.
Have tried the limit switches in all possible positions but no go.
The board is marked SIEG MACHINE and does not appear to have any black or sooty spots on the front, have not looked at the back as noit easy to get to.
HELP NEEDED please!
I think the unit is now discontinued but I know SIEG is still around.
Martin
