MEW article on coupling a stepper motor to a Vertex Rotary Table
Home › Forums › Help and Assistance! (Offered or Wanted) › MEW article on coupling a stepper motor to a Vertex Rotary Table
  • #33871
    Greensands
      @greensands
      Problems in sourcing SPDT Mom (On) OFF (On) Rocker Switches
      #557100
      Greensands
        @greensands
        I am currently having problems in sourcing a couple of Mom (On) Off (On) rocker switches required for the Arduino stepper motor project. Only available items appear to be located in the US. Is anyone aware of a possible UK source?
        #557102
        Stuart Smith 5
          @stuartsmith5
          Are any of these suitable:
          from CPC.
          Stuart
          #557104
          Emgee
            @emgee
            Is that the same as SPDT with centre OFF ?
            DPDT available on eBay in various forms from several UK sources.
            Emgee
            #557105
            Greensands
              @greensands
              Yes, that looks just the ticket. Many thanks for the link
              #557110
              Greensands
                @greensands
                Have just checked out CPC for the SPDT switch Type 1818.1302 manufactured by Marquardt but they are only taking back orders. There seems to be a world wide shortage for this and many other items due to Covid issues.
                #557131
                Oven Man
                  @ovenman
                  Would something like this be suitable? It's a toggle switch rather than a rocker, probably more robust.
                  Momentary Toggle Switch
                  Peter
                  #557164
                  duncan webster 1
                    @duncanwebster1
                    You could always use 2 push buttons instead
                    If those from Oven Mans link will do I have a couple you're welcome to, but they might be too big
                    #557172
                    Greensands
                      @greensands
                      Oven Man/Duncan – I think the physical size and current handling capacity of the units suggested are a bit OTT for the given application. I checked the Dims and was surprised to see just how big and 'meaty' in both senses they actually are.
                      In their place I have opted for the miniature version having the same Mom On-Off-On action, smaller current rating and fitting ia 6mm panel hole. Costs in each case are very reasonable.
                      Many thanks for all the help provided
