Material source needed
Home › Forums › General Questions › Material source needed
Viewing 14 posts - 26 through 39 (of 39 total)
  • #232698
    Speedy Builder5
      @speedybuilder5
      Someone make this guy a small cutter – its quicker than posting replies. I would, but by the time it came from France, he would have got it out anyway. Dimensions – I/d 0.09" and O/d as small as it looks possible. Then Mr Bugbear, once the screw is removed, fill with sawdust and superglue or wood filler and 'Bob's yer Uncle'
      BobH
      #232699
      Ed Duffner
        @edduffner79357
        How about a TRS jack plug shaft? 1/4" 1/8" 3/16" etc.
        Ed.
        #232706
        Bazyle
          @bazyle
          How about spark eroding it out – the heat might free it up anyway. hot
          #232715
          mike T
            @miket56243
            How would you do that Bazyle? It's in wood !!!!!
            #232718
            Frances IoM
              @francesiom58905
              maybe it’s an electric guitar!
              #232743
              mike T
                @miket56243
                At least that should help.
                Edited By mike T on 31/03/2016 22:56:17
                #232747
                HughE
                  @hughe
                  What about these
                  http://www.highlandwoodworking.com/set3hollowscrewextractors.aspx
                  Just made one for 8 guage screws but i have a lathe which helps
                  #232770
                  bugbear6502
                    @bugbear6502
                    Posted by HughE on 31/03/2016 23:27:21:
                    What about these
                    Yes, those are the larger (see Stewmac) commercial product. They're also in the USA, and I'm in sunny Norfolk.
                    I have a box of cheap (£3.99 for 120) roll pins coming, and a friend just came into work with a couple of feet of scrap stainless steel aircraft fuel line.
                    BugBear
                    #232834
                    bugbear6502
                      @bugbear6502
                      Fuel line turns out to be really well annealed so you can bend it;
                      I have made a prototype hole saw; a friend gave me some scrap engine fuel line, which turns out
                      to be well annealed (so you can bend it) steel. Easy to file.
                      The OD is 5.5mm, I don't know the ID.
                      I filed 5 teeth around the circumference, with each tooth face on a radius.
                      On trial, the problem (shared with the commercial versions?) is that you have a saw with no means of removing the sawdust, so you have to keep withdrawing the bit to brush dust off the bit, and to (try to) blow out the hole.
                      So I returned to my teeth filing, and with the tube raised high in the vice, used a 45 degree slope to make a VERY large gullet on each tooth for the dust to go in. The dust still has no means of actual escape, but the teeth hold more now. This seems to work OK.
                      BugBear
                      PS Macro photography makes your filing look awful!
                      Edited By bugbear6502 on 01/04/2016 17:14:34
                      #232890
                      peak4
                        @peak4
                        Posted by bugbear6502 on 30/03/2016 13:42:51:
                        I was considering recycling the telescopic aerial from an old radio (chrome plated brass).
                        BugBear
                        If you have a military surplus dealer round your way, try sections of tank/Landrover radio aerials; they are made of painted, copper plated, spring steel tubing, rather than chromed brass.
                        Edited By peak4 on 02/04/2016 00:51:25
                        #232893
                        MW
                          @mw27036
                          Looks like you made a decent job of it. Well done.
                          Michael W
                          #232898
                          bugbear6502
                            @bugbear6502
                            Posted by peak4 on 02/04/2016 00:49:36:
                            BugBear
                            How interesting – thank you.
                            BugBear
                            #233187
                            bugbear6502
                              @bugbear6502
                              In case anybody else is looking for materials, I can say that the fuel line is probable just mild steel,is super-annealed, with an OD of 6mm and ID around 3.7mm.
                              BugBear
                              #234198
                              bugbear6502
                                @bugbear6502
                                I was waiting for delivery of a box of mixed roll pins.
                                Waited and waited. Went to eBay to check my order, and chase the seller.
                                Yep – still in my Watch list. blush
                                They arrived today; for anyone following along, I can confirm that they're certainly harder than my fuel line, but still eminently soft enough to file, so I won't need to follow up my musings on gas-hob annealing.
                                BugBear
