Posted by Stub Mandrel on 28/06/2013 19:34:12:
Up in the Brecon Beacons two mates and I 'melted' a primus stove. We put it out using wet socks.
The one guy (Richard?) soldered it back together and returned it to the school. I just hope it was never used again.
Re-assembled many of these during my time as a scout leader. If no leaks no reason not to use.
I suspect the use of soft solder for assembly is deliberate as it permits controlled failure – i.e. on overheating the thing falls apart before there is any significant pressure build up. You may have a local fire but it will not explode and kill you.
By the way Neil, next time, if you pump too soon and get a flare-up undo the pressure release screw in the filler cap. The stove will go out and probably not fall apart. This means you get a second chance at cooking breakfast.
