Magnetic centroid
Magnetic centroid
Home › Forums › General Questions › Magnetic centroid
Viewing 21 posts - 1 through 21 (of 21 total)
  • #24492
    Sam Stones
      @samstones42903
      Hardly model engineering
      #234387
      Sam Stones
        @samstones42903
        This has hardly anything to do with model engineering, but …
        As a kid (some considerable time ago now, and far less traffic) I enjoyed jumping on those wide rubber strips built into the road. Many readers will recall that the strips changed the traffic lights in favour of vehicles running over them. If you stamped hard enough, you too could `take control’ of the lights.
        Then there were the cat’s-eyes, which shot a jet of water upwards if you stamped on them. If you got it wrong, the water would shoot up the leg of your shorts.
        These days, we can see where inductive loops lie below the road surface. As upside down metal detectors, they are typically less sensitive to larger vehicles raised higher off the road.
        My question is however, –
        For best effect (sensing), where would you expect the magnetic centroid of a vehicle to be?
        Sam
        #234390
          Posted by Sam Stones on 12/04/2016 22:54:59:
          It must obviously depend upon the materials used in the construction of the vehicle, but; my first approximation would be 'the same place as its centre of gyration'.
          Sam Stones
            @samstones42903
            I like that idea Michael.
            I suppose the next part of the question relates to the power relationship – i.e. Distance relative to the magnetic flux/density. Somewhere in my flimsy memory is the notion that magnetism falls off by the 7th power of the distance, but that doesn't feel right.
            Sam
            Edited By Sam Stones on 13/04/2016 00:02:31
            #234403
            Chris Evans 6
              @chrisevans6
              Will the trend to build aluminium cars trigger a rethink?
              #234404
              Roger Hart
                @rogerhart88496
                I would guess that the frequencies involved are pretty low and the presence of any metal surface thicker than about 0.1mm will screen off anything beyond – at least so far as detection is concerned. So the idea of a centroid might not apply, just the distance and area. Ferrous or not should not matter.
                I like the idea of squirting cats eyes though.
                #234405
                  Posted by Chris Evans 6 on 13/04/2016 07:22:24:
                  Chris,
                  I thought I covered that in my first response.
                  Edited By Michael Gilligan on 13/04/2016 07:56:25
                  #234406
                    Posted by Sam Stones on 13/04/2016 00:01:44:
                    I suppose the next part of the question relates to the power relationship – i.e. Distance relative to the magnetic flux/density. < etc. >
                    Getting way out of my depth there, Sam … but I would suggest that you start exploring the 'HyperPhysics' site.
                    P.S. … Some assurance that you are not designing a Mine would bring comfort. surprise
                    #234408
                    john carruthers
                      @johncarruthers46255
                      The magnetic sensor on a private carpark near me will trigger if you get the engine over, or near, the sensor from the 'outside'.
                      It entails slowly driving your bonnet under the exit barrier until it unlocks wink
                      Rear engined vehicles are out of luck.
                      #234409
                        Useful **LINK**
                        Edit: and this is rather more technical.
                        Edited By Michael Gilligan on 13/04/2016 08:20:05
                        #234412
                        Howi
                          @howi
                          Edited By Howi on 13/04/2016 08:47:40
                          #234416
                          Chris Evans 6
                            @chrisevans6
                            Michael, I should read the posts a little better. My excuse is it was early and the coffee had not yet wakened me. Chris.
                            #234422
                              @mike89748
                              Unless things have changed in the last 20 or so years, it doesn't take much steel to trigger the light-changing mechanism. A pal who was a traffic lights engineer for the local council used to test lights by walking over the mechanism carrying a dustbin lid. I don't really understand the technicalities of this discussion, but I suggest there is enough steel in an aluminium-bodied car to do the business.
                              #234423
                                No problem, Chris
                                It's turning into an interesting topic. yes
                                Ajohnw
                                  @ajohnw51620
                                  Posted by Michael Gilligan on 13/04/2016 08:07:10:
                                  Useful **LINK**
                                  The 2nd one is interesting Michael. A friend of mine was convinced that they were being used to detect speeding in some areas of the country.
                                  Jon Gibbs
                                    @jongibbs59756
                                    There is no need for the vehicle to be ferrous-based to trigger such an upside down metal detector in principle since any metal object will have eddy currents induced in it by the fluctuating magnetic field around the coil which either changes it's impedance or the magnetic effect of the eddies can be sensed by a receiving coil.
                                    [Edit: Sorry I just saw Michael's link and it is confirmed… "The ferromagnetic effect increases loop inductance. However, vehicle-induced eddy currents decrease loop inductance even more. Therefore, net effect is decreased loop inductance when a vehicle passes through the detection zone of an inductive loop."]
                                    My old Dad used to have a very crude metal detector in the late 70's when I was a kid and we spent all of our time digging up old drinks can tabs, which were aluminium of course and before they had to be captive.
                                    It'd also be a pretty pointless hobby if all you could find were ferrous rusty blobs and no prospect of gold or silver coins although I don't remember us finding anything other than the drinks can tabs
                                    Jon
                                    Edited By Jon Gibbs on 13/04/2016 09:47:52
                                    #234489
                                    mark costello 1
                                      @markcostello1
                                      Jumping up and down on traffic control and getting a splash? Never heard of them. You Guys have all the cool toys!
                                      #234490
                                      Ajohnw
                                        @ajohnw51620
                                        They are usually called cat's eyes Mark Small square things that mark traffic lanes etc. The idea is that from time to time traffic drives over them which forces the top part down and in doing so wipes the small round reflector clean. I'm sure they are all over the world.
                                        Water collects in them so jump hard enough and it squirts out.
                                        Jon Gibbs
                                          @jongibbs59756
                                          Cat's eye description here… **LINK**
                                          #234541
                                          Sam Stones
                                            @samstones42903
                                            Many thanks to M.E. contributors.
                                            A special` thank you’ to Percy Shaw, Edward Current, et al for steering me through some of this labyrinth.
                                            From the little I can find out, it appears that the (attraction/repulsion) force exerted between two magnets or between a magnet and another object being attracted can vary between the distance cubed and the distance to the seventh power. Something to do with shape again.
                                            Knowing how to approach and position my car over the loops will never be the same again.
                                            Regards to all,
                                            Sam
                                            #234542
                                            simondavies3
                                              @simondavies3
                                              Posted by Mike on 13/04/2016 09:17:10:
                                              Having run a number of fibreglass cars over the years, I can recall several occasions where I had to wait at the traffic lights for somebody else to trigger the sensors – rather frustrating.
                                              On the up side, the old radar traps that the Gendarmarie used to use were insufficently sensitive to detect me at speed.
