Posted by Roderick Jenkins on 14/10/2016 13:40:19:
Posted by JasonB on 14/10/2016 13:19:38:
Would TCs findings be based on carbon steel taps?
Probably, that's all the impecunious model engineer could afford. But that's really my point: If you don't have the best equipment then best practice isn't necessarily for you.
Some of the contributers to this thread, looking at it from an industrial perspective, seem to be insisting that there is a "correct" answer. All I'm trying to say (ad nauseam) is that there isn't. There are other options, depending on the application.
Tapping Fluid. Actually, I don't have any – I use a tiny little tub of what the kind fitter who gave it to me decades ago referred to as "Goose S**T". And It's nearly all gone
Rod
Your 100% right Rod but pointless arguing with the perfect world people were everything is exact including taps. Fact is they are not exact, neither are drills or the bits that go into the holes. It's also perfectly possible to do adequate jobs with cheap stuff. Eg if a tap isn't going to be used much why buy ground hss when cut thread will do. My most used taps come from Screwfix. HSS and size wise no different to far more expensive brands. The split dies have a very unusual adjustment fitting which doesn't work that well. I recently bought some serials from ArcEuro. As expected there is more size variation. I wouldn't expect any different given the price.
Those that want exact should go for the precision parts too. The price of the screws would shock most people and they are still not exact.
I often use a scraping of hand soap as a lubricant for tapping. I do have some of the "proper" stuff but it's messy and not any better. Hadn't thought of trying goose fat. It is odd stuff as far as fats go and can be bought from supermarkets for superior roast potatoes. I've bought some lubricant type tallow – what I always used at work and gave excellent results. It will get tried eventually. Last time this cropped up I remembered something – sperm whale oil when it was available was the best of the best for a tapping lubricant. The modern equivalent is jojoba oil so I will probably try some of that too.
LOL Tap's back cutting clearly doesn't matter round here.
