M6 thread locking/stiff screw
Home Forums General Questions M6 thread locking/stiff screw
Viewing 6 posts - 26 through 31 (of 31 total)
  • #565165
      Rob,
      I do recall [from at least 30 years ago] reading about a similar-looking system which used micro-encapsulated anaerobic adhesive … released like the ‘scratch & sniff’ perfume samplers.
      But I haven’t ever seen it on the general market
      Howard Lewis
        @howardlewis46836
        As Michael says, MEAS was very popular a long time ago, in industry. (Possibly still is? ) used on fasteners of all sizes, at the time
        I have a small drawer filled with such 8 – 32 UNC grubscrews that I inherited. Try to use when locking a screw is needed, such as dutch keys. Too good to waste
        #565229
        modeng2000
          @modeng2000
          Well the answer I have used to make stiff threaded screws is to place a length of thread down the hole before inserting the screw. The thread I used was model kite cord but I don't know what it is made from.
          The screws can be re-adjusted it seems without loosing the stiffness.
          Harry Wilkes
            @harrywilkes58467
            Posted by Michael Gilligan on 02/10/2021 10:31:43:
            Rob,
            I worked for a UK company that specialised in all forms of thread locking, sealing etc the micro-encapsulated anaerobic adhesive we applied was supplied by 3M's basically the hardener was suspended in the adhesive and when the fastener was screwed in to a thread the capsule was broken allowing the hardener and adhesive to mix most of the production was cylinder head bolts, in the case of the fasteners which a torx drive we had to make sure the adhesive was applied to the correct end assembly robots were not colour blind they were 'thick' not being able to tell one end from the other wink
            H
            #565477
            bernard towers
              @bernardtowers37738
              I seem to recall that the tri lobed screws where called Taptite as they were hard and screwed straight into sheet material making their own threads. I still have some they must be at least 40 years old now!!
              #565762
              modeng2000
                @modeng2000
                Just an up-date to say that following some use of the lathe, the carriage gib adjustment has not changed. So the use of a synthetic thread to stiffen the screws has provided a workable solution to this problem.
