Listed on ebay as easily repaired
Home › Forums › General Questions › Listed on ebay as easily repaired
  • #555468
    Former Member
      @formermember12892
      #28270
      Former Member
        @formermember12892
        #555481
        Bob Stevenson
          @bobstevenson13909
          ….It is easily repaired,….just bung it in the scrap and make a new wheel!………..(note cracked spokes!)
          #555482
          Rob McSweeney
            @robmcsweeney81205
            Never mind the flange, which could be built up with weld and re-turned , the spokes at 1 and 2 o'clock look to be cracked at the root.
            #555487
            not done it yet
              @notdoneityet
              Could be turned down and a new ‘tire’ shrink fitted. But what about the other wheel on that axle (and all the rest, for that matter)?
              I’m not considering buying it so I’m not going to worry about it, for sure.
              #555490
              Martin Connelly
                @martinconnelly55370
                Dropped at some point I would guess.
                Martin C
                #555491
                Rob McSweeney
                  @robmcsweeney81205
                  What is the model – are the wheel castings still available?
                  #555493
                  Nicholas Farr
                    @nicholasfarr14254
                    Hi, you could clean the wheel in a ultrasonic cleaner and probably fill the cracked spokes with brazing and then as NDIY fit a new tyre by shrinking or using some high strength cylindrical retaining compound, which would be easier if the wheel is not too difficult to remove, or like Bob has said, fit a new wheel, but failing every thing else, if you have the skill, making a completely new wheel set would probably make it an economical repair. Like NDIY, I'm not going to buy it, so it won't bother me either.
                    Regards Nick.
                    #555496
                    Former Member
                      @formermember12892
                      #555511
                      Dalboy
                        @dalboy
                        I like the comment at the bottom of the ad
                        "Condition is "Used" but like new. As far as I can work out it has never seen daylight!"
                        #555530
                        Mark Rand
                          @markrand96270
                          Probably why it got dropped then, someone tripped over with it in the dark.
                          #555537
                          BOB BLACKSHAW 1
                            @bobblackshaw1
                            Last comment made me laugh.
                            #555540
                            Brian H
                              @brianh50089
                              It would be a shame to spend time and money on the repair only to find more damage afterwards.
                              #555544
                              old mart
                                @oldmart
                                If I was listing it, I would be honest and say that it could be repaired by an expert.
