Linear Slide Fricion.
Home Forums General Questions Linear Slide Fricion.
  • #268143
    Chris Denton
      @chrisdenton53037
      I need to build something with slides that will travel with a small amount of friction, will these be suitable?
      Thanks.
      http://uk.rs-online.com/web/p/linear-guides-rails/4885057/
      Edited By Chris Denton on 23/11/2016 21:51:27
      #24896
      Chris Denton
        @chrisdenton53037
        #268144
        Ian P
          @ianp
          I'd like to be able to offer an opinion but really you are the only person that knows what 'small amount' is acceptable.
          Ian P
          #268145
          Chris Denton
            @chrisdenton53037
            That's true!
            It should be able to move by pushing with your little finger using moderate force!
            #268187
            Ian S C
              @iansc
              What's it made of, what weight is on it, how fast does it move, and how often. There are probably a few more questions that should be asked.
              Ian S C
              #268207
              John Haine
                @johnhaine32865
                I suggest that you look at linear ball bearings as used in 3D printers, significantly cheaper and use ground silver steel bars. See here for example. Friction is very low, if you need more you could always add a "brake" of some kind.
                #268220
                Russell Eberhardt
                  @russelleberhardt48058
                  Posted by John Haine on 24/11/2016 12:14:49:
                  Better to use those bearings with shafting like this rather than silver steel which will need hardening and is likely to distort.
                  As said above though it does really depend on your application.
                  Russell
                  #268279
                  Chris Evans 6
                    @chrisevans6
                    When I was working I regularly bought from bearing suppliers "Linear Shafting" and linear bearings. For what you get not pricey either.
