Lathe/Mill motors
Lathe/Mill motors
Home › Forums › Beginners questions › Lathe/Mill motors
  • #272449
    Terry Howlett 1
      @terryhowlett1
      I became interested in model engineering about 5 years ago and subsequently purchased a minute Unimat ML combination lathe/mill/drill a while back as a stop gap to getting into model engineering proper. After a few years delay due to illness and other matters, I have finally moved house, I have workshop space, more time and even funds(!) to get myself equipped with a proper lathe and perhaps a dedicated mill.
      In looking at various specific lathes including Axminster (and other SIEG brandings), Warco, Swisstec, Optimum etc, I'm trying to get my head around the differences between motors that are brushless, compared to conventional and how they affect the performance of the machine, or appropriateness to the job. I also want to understand the merits of 3 phase supply over domestic single phase.
      Is there a published summary or a link somewhere that anyone can recommend that might help me along the way, or can someone offer a potted summary?
      Many thanks
      Terry
      #8444
      Terry Howlett 1
        @terryhowlett1
        #272459
        Brian Oldford
          @brianoldford70365
          I think your question needs to clarify what type and size of work to expect to do. Big subject indeed.
          Edited By Brian Oldford on 17/12/2016 21:03:23
          #272463
          Gray62
            @gray62
            Came across this today, might help you with the differences between brushed and brushless DC motors
            #272466
            Terry Howlett 1
              @terryhowlett1
              That was helpful Graeme, thanks.
              Yes Brian, I realise I was a bit vague there. Initially I want to get much better practiced at turning and general engineering by producing some small components or useful add on machine tooling, then maybe construct a model from some kitted castings. As my experience and confidence grows I will eventually look at building some sort engine, be it I/C, hot air or even steam powered. I doubt I'd ever build anything bigger than say 3 1/2 inch maximum with smaller gauges more likely. I'm also very interested in restoring old mechanical objects back to working order.
              I'm looking at lathes like the Axminster SC4 or 6, or perhaps the Warco WM 250. I notice Pro Machine Tools offer a range of lathes branded as Swisstec, the ST-250 looks similar to the Warco, but they are offering the package with DRO.
              Some thinking and big decisions to make but I'm keen to get started in the new year. I'm semi retired and will probably retire full time in a year or so, and Model engineering of some form has always been calling me!
              Hope that gives some idea.
              #272486
              not done it yet
                @notdoneityet
                A three phase supply is an extravagance for most. Three phase for the occasional drive can easily be derived from the single phase domestic supply for lower powered drives.
                Not an electrical expert, but as I see it, the advantages of a three phase motor are that it gets an energy 'kick' every 120 degrees, self starts and has even power pulses – so is generally smoother in operation than a single phase motor (with run capacitor) or a 2 pole motor. They are likely a little more efficient (neither here nor there for hobbyists!) and tend to come in smaller frame sizes (415V)  for equivalent power output (with reliability). They are easy candidates for variable speed control, which makes them a favoured choice, for many, in conjunction with a variable frequency drive (VFD) running from a single phase domestic supply.
                Edited By not done it yet on 18/12/2016 07:37:13
                #272489
                Gary Wooding
                  @garywooding25363
                  "Came across this today, might help you with the differences between brushed and brushless DC motors"
                  Seems to me that it shows that a 500W motor is more powerful than a 250W motor, or did I miss something?
                  #272491
                  Gray62
                    @gray62
                    Posted by Gary Wooding on 18/12/2016 07:52:05:
                    No you didn't miss anything, I DID!, had skim read it but didn't really pay attention to the ridiculous comparison they were making, should have compared 250 for 250W or 500 for 500W otherwise the exercise is pointless as a 500 watt brushed motor would have given similar results against a 250W brushed.
                    Still, the OP found it helpful so it wasn't a totally wasted link
                    #272500
                    John Haine
                      @johnhaine32865
                      Many smaller (and generally cheaper) machines use DC motors, mainly I think because they can easily be speed controlled so saving on mechanical speed reduction. (Mechanics more expensive than electronics these days.) Some DC speed controllers are a bit fragile, especially it seems those fitted to small mills and lathes (e.g. the X1 mill, see various tales of woe here). Brushed motors are traditional but the brushes can wear out. Brushless require electronics to drive them – they have only appeared on amateur machines in the past couple of years, so reliability perhaps an unknown quantity. They can also be more powerful in a given size I think. I have a small CNC mill (Denford Novamill) with a 1/2 hp brushed DC motor run from a "proper" KB Electronics controller and more than once I have stalled the drive (doing something silly) – once the fuse blew but the drive survived, so they can be robust.
                      Single phase induction motors are cheap to make, very reliable, quite efficient, but need AC to make them work – but AC comes out of the mains so isn't a problem. They can't be efficiently speed controlled so you need belts/gears. Because of the way they work their torque varies cyclically slightly out of phase with their rotation, hence vibrate a bit. But most small machine tools have done very well with them for decades. Also (in reasonable power versions) they need special means to make them start, usually consisting of an extra winding and a capacitor, and generally a centrifugal switch. The capacitor and/or switch sometimes give trouble. By changing the way the extra winding is connected they can be reversed. Maximum power is generally up to 3/4 hp or so. They generally come in 2-pole, ~2900 rpm; or 4-pole, ~1425 rpm (on 50 Hz). Poles and volts are unrelated.
                      3-phase induction motors are also cheap to make, very very reliable, efficient, but need a 3-phase supply. They start on their own and can be reversed by swapping over two connections. Again, 2-pole and 4-pole are common. Speeds (on 50 Hz) the same as single phase. Industrially they sometimes run on 415V phase-to-neutral, in a star winding configuration. Such a motor will need rewiring in a "delta" to run on a standard 3-phase "domestic" supply which is only 230V phase-to-neutral. This may be easy or hard depending on construction! Rotation is very smooth and vibration free (as long as the motor is properly balanced). The magnetic circuit of a 3-phase machine is more efficient so they can give more power in a given frame size.
                      These days a 3-phase motor can be fed from an "inverter" or Variable Frequency Drive (VFD). These allow you to vary the speed from virtually stopped up to rated speed up to (in principle) as high as you like. I run my mill up to 75 Hz, 50% over plate RPM. The VFD can be fed from single phase (usually), or the higher power ones 3-phase.
                      There is nowadays no point whatever in having a 3-phase supply connected to your house unless you need a lot more power than you can get from a standard single phase supply, as you can run a 3-phase motor from a VFD. Indeed it's better using a VFD because you get variable speed as well.
                      In summary,
                      • If you are looking at a hobby size machine, if it's a type that has a DC motor then ask around on the ME forums to see what sort of reliability people are getting.
                      • There are some machines that are fitted with a 3-ph induction motor and VFD – I think these are likely to be better and more reliable. Industrial grade VFDs are readily available and quite cheap if you needed to replace the original one.
                      • If you buy a used machine, you would probably be very happy with a standard single-phase induction motor but could improve it by fitting a 3-phase motor and VFD. (Or if you get a used industrial machine with 3-phase, add a VFD and use it on your single phase supply.)
                      • Don't worry about getting a 3-phase mains supply unless you want to run a big muffle furnace or electric kiln!
                      #272501
                      Anonymous
                        Posted by not done it yet on 18/12/2016 07:35:30:
                        It's a bit more subtle than that. In a 3-phase motor the magnetic field is a pure rotating field, so there are no energy 'kicks'. That's why a 3-phase motor is smoother in operation than a single phase motor.
                        I have a proper 3-phase supply at home, primarily because I mostly use ex-industrial machines with large motors by ME standards. And I want all the ancillaries such as coolant pumps and power feed motors to work without any fuss. However, my CNC mill runs on single phase and uses VFDs for both the main and high speed spindles.
                        For the size of machines being discussed a true 3-phase incoming supply is of no advantage.
                        Edit: I disagree with John, I'd much rather have a 3-phase supply than muck about with lots of VFDs for my industrial machine tools.
                        Edited By Andrew Johnston on 18/12/2016 10:22:58
                        #272502
                        John Haine
                          @johnhaine32865
                          Posted by Andrew Johnston on 18/12/2016 10:15:35:
                          But as you say Andrew, you have a lot of big machines!
                          #272511
                          Terry Howlett 1
                            @terryhowlett1
                            Thanks everyone.
                            Graeme and Gary, I think I missed that also as I was focused on the data and the penny hadn't dropped they were not comparing like for like!
                            John, that really helps to get my head around everything that I need to consider. I had noticed some machines show that the drives are "Inverter" Drives and that in itself was adding to my confusion but I think I get what they are now. So I'm concluding that I will likely focus on a brushless machine like the SC4 or a slighter bigger machine with an "Inverter drive". Just need to understand some of the machine specifications that are published by the manufacturers!
                            Re the Swisstec lathes (ST-250 for example), apart from Pro Machine Tools website I cant find much else on the web. Does anyone have a view on these?
                            Thanks again
                            #272514
                              Terry,
                              You might find this recent thread of interest: **LINK**
                              http://www.model-engineer.co.uk/forums/postings.asp?th=122544
                              Terry Howlett 1
                                @terryhowlett1
                                Michael,
                                Thanks for that link. There is certainly an interesting thread there!
                                #272984
                                Nick Hulme
                                  @nickhulme30114
                                  Lots of reference to VFD as if it's something that only changes single phase to three phase but Variable frequency drives are predominantly used in industry to change the frequency of three phase supplies in order to run motors at variable speeds and/or speeds not available with the basic supply.
                                  If I had three phase to my workshop I'd still use VFDs because variable speed is an absolute godsend in a variety of circumstances, the sad part is that until you've run a machine with variable speed and made propper use of the facility you won't understand how useful it can be
                                  – Nick
                                  #273004
                                  Bazyle
                                    @bazyle
                                    That was a very good explanation from John H which could be a nice section for the next beginners guide MTM bring out.
                                    Just one thing to add. If you find yourself looking for a 3 phase motor to use with a VFD you need to find one with both voltages on the plate eg 220/415 . This shows they can be changed to the necessary lower voltage easily as opposed to maybe but with difficulty.
                                    People will keep saying how they converted a 415 only motor by finding the 'star point' but these people never offer to find it for you underneath all the wires and binding on your particular one without damaging anything.
                                    #273041
                                    Terry Howlett 1
                                      @terryhowlett1
                                      Yes that was a good explanation from John H. Everyone has been helpful to varying degrees. I think my next step is to look at some of these machines at Alexandra Palace in a few weeks.
                                      Thanks again all.
                                      #273085
                                      Martin Kyte
                                        @martinkyte99762
                                        Good point Nick
                                        Some musing.
                                        Variable Frequency Drives were developed for motor speed control in the first instance. Like it says on the tin. generally they were used, for example, in conveyor systems for goods handling where good speed control was required and provided an excellent control element which could be readily integrated into production line set ups etc.
                                        All the first ones I used had 3 phase inputs so their only function was speed control. Once a unit like that had been developed there was no great design leap to move to single phase input 3 phase output or any other combination.
                                        Clearly the functionality to run 3 phase machines from single phase supplies is useful particularly in many of our workshop arrangements and we do tend to see this as the main function of VFDs because that often is the problem we are solving.
                                        Good engineering is all about the most elegant solution to particular problems and the ideal solution to Andrews needs to drive large 3phase machines is a dedicated 3 phase supply. However I suspect if he moved house and the only way to lay on 3 phase in his new place was to lash out £10,000 because of the remote location or other such difficulty in changing his supply rotary converters or VFDs may start to become more attractive although Andrew would probably say he wouldn't move to a house like that.
                                        PS Most locations 3 phase would be much cheaper than that. My workshop has a pole with overhead 3 phase out side in the road. So all I need would be a new drop onto the gable of the workshop. No trenches or roadworks or anything. I still don't bother as I only run 1hp motors on the mill and lathe. (On VFDs I hasten to add)
                                        regards Martin
                                        #273092
                                        Muzzer
                                          @muzzer
                                          Some 3-phase machines are a bit too complex to simply accept a VFD, eg where there is a 3-phase transformer on the input with lots of different components powered from it eg a mixture of single and 3-phase.
                                          You can't simply run a 3-phase transformer from the output of a VFD without some interesting (expensive) filtering between them, so instead you have to either power the whole thing from a phase converter or dive in there, remove the 3-phase transformer and provide alternative sources for each of the subsystems. It's usually only the spindle motor and the hydraulic and coolant pumps that require 3-phase (one or two VFDs) while the rest of the gear (the controller, switchgear, lighting, display etc) is usually powered from one phase, so can be provided with a single phase supply, either directly or via a (single phase) transformer.
                                          Phase converters may be the simplest solution but given their cost it may often be worth taking a different approach. As you may have deduced, I'm in the middle of such a conversion myself. I see a cost-effective solution but it will require some reconfiguration of the innards of my machine to make it accept single phase.
                                          Murray
                                          #273098
                                          Martin Kyte
                                            @martinkyte99762
                                            I'm sorry, I was using the word "machine" to signify the motor only not the machinery to which it was attached.
                                            No such thing as a 3 phase lathe just a lathe with a 3 phase motor. Should have been more precise.
                                            regards Martin
                                            #273121
                                            Muzzer
                                              @muzzer
                                              Hi Martin – I wasn't replying to your post as such – not problem with it at all with it. Just thought this thread was a relevant place to make a couple of observations in the light of my current activities.
                                              Murray
                                              #273128
                                              Martin Kyte
                                                @martinkyte99762
                                                Didn't think you were Muzzer. Just that your post reminded me that non electrical engineers perhaps would not call electric motors machines.
                                                Martin
