Hi Chris
Dirt under the saddle?
Tool height is over or under your normal centre height. Or (But even so it should turn straight)
The tool is incorrectly set and is pushing the work away as it cuts. If that is happening it will turn a larger diameter towards the tailstock. Was the work you did very thin?
Edit Hmm missed the 16mm. That should be fairly stiff over 4cm? Was the tool in good condition.
But the fact that the thicker test was half the error suggests the centre height may be the culprit. In smaller diameters quite critical or you get a taper. Maybe there was a bit of deflection too on the smaller diameter cut.
Place a dial indicator against the side of the chuck with a heavy bar gripped in it as a leaver push it to and away from you by hand. Does the indicator move? you may get a few tenths of movement if it has plain bearings. any more and the spindle may need adjustment.
john
Edited By John McNamara on 19/02/2014 14:01:42
Edited By John McNamara on 19/02/2014 14:06:17
Edited By John McNamara on 19/02/2014 14:13:15
