Hello Peter,
I built my whole machimery bench onto a framework of Dexion slotted angle, it carries the Myford ML7B, a Dore-Westbury vertical mill and a New Progress 1/2 inch capacity bench drill.
I just made sure that there were Dexion bearers under the load points for the machines with the weight carried vertically down through more angle as legs, all screwed down to a concrete floor cast onto a membrane sheet.
The top is flooring grade chip board with thin hardboard packing to level the steps in the joints from the framing and counterbored sockets to contain the bolt heads, the whole lotis topped off with a sheet of hardboard under the swarf trays.
It has never moved in 15 years and the space underneath has tool and equipment drawers all fully loaded so there is a fair mass supported on the Dexion frame.
I made my own raising blocks from 2" x 4" hollow box section steel of 6 mm wall section and bolted the machines through those to the Dexion framing.
I hope that helps you decide
Edited By Brian Wood on 09/02/2015 19:11:12
Edited By Brian Wood on 09/02/2015 19:13:11
