Re: Duchess of Swindon.
Dean,
Don't know if you are aware of this but the intended 6 part construction series was stopped abruptly after LBSC resigned from writing for Model Engineer. The two parts that were printed got as far as locomotive frame erection, buffers, and coupled-wheels. The design was intended to allow maximum latitude and variability to the prospective builder.
Roy Boulcott built a (possibly unique??) Duchess of Swindon by using previous LBSC designs such as Britannia and Hielan' Lassie. He corresponded with LBSC who drew up the valve-gear specifically for him. This is the example pictured in the book LBSC, His Life and Locomotives, Hollingsworth.
LBSC himself intended that the loco' could be completed as two or four cylinder, piston or slide-valve (with his-own preference being for piston valves), and could be finished off with any superstructure.
The leading bogie was to be similar, albeit with significant differences, to the Schools class.
On two cylinder loco' cylinders were to be similar to Britannia, four cylinder version to have cylinders and valve-gear 'much the same' as the Great Western 'King' class.
Valve gear follows Britannia, but with pole reverser and 'standard' reach-rod with intermediate support.
Coupled wheels as specified for Princess Marina = scale 5' 6".
Boiler taper barrelled with Belpaire firebox with wide grate and combustion chamber. Fitted with multiple element superheater. Two cylinder engine has wide Great Western type chimney, albeit shorter than produced 'in real life'. Multiple jet blast-pipe. Four cylinder version may be fitted with double-chimney.
Boiler to be fitted with a dome containing sliding vale regulator. Safety-valves to be off-centre 'as on Britannia'.
Trailing pony-truck 'follows the Gresley design on old LNER', but similar to Britannia's, but with the spring outside like the usual sort of tender. Same axlebox and spring design to be used on tender.
Steam brake on all coupled wheels.
Tender to be six-wheeled similar to LMS Duchess class, but builders could substitute eight-wheeled Gresley Pacific type or Urie eight-wheeled bogie type – as preferred.
Sorry to drag your Ivy Hall thread off-topic. But, responding to your mention of Duchess od Swindon in your posting immediately above.
Phil
