Inverted parting tool
Home Forums General Questions Inverted parting tool
  • #530379
    Andy Sproule
      @andysproule22368
      Hi,I have a boxford 280 lathe with a Bison dickson type toolpost.I was going to try parting off with the blade upsidedown and the chuck running clockwise but the holders can't be risen to centre height any ideas how this could be done?download.jpg
      Andy Sproule
        @andysproule22368
        #530382
          Probably have to see if you can drill and tap the underside for a new height adjuster and then mount the whole thing upside down. Holders are quite hard so not easy to drill & tap.
          #530384
          Emgee
            @emgee
            I suppose another toolholder designed for the inverted tool is required,
            Emgee
            #530391
            Nigel Graham 2
              @nigelgraham2
              Is there a particular reason for this approach though?
              Usually, parting with an inverted tool is from a rear tool-post and the lathe running in the normal anticlockwise direction. It tends to be a more rigid set-up; but obviously needs a cross-slide capable of holding the tool-post.
              #530399
              Speedy Builder5
                @speedybuilder5
                What will stop the saddle lifting off of the bed ?
                Is the chuck a screw on one ? if so, what stops the chuck unscrewing ?
                #530403
                old mart
                  @oldmart
                  You need to make a rear toolpost, then you can use any size blade in any size lathe.
                  #530410
                  David George 1
                    @davidgeorge1
                    If you have a screw on chuck just make the rear toolpost with the blade upside down.
                    David
                    #530446
                    John Reese
                      @johnreese12848
                      Inverted parting tools in a rear toolpost work so well because if rigidity an the fact that deflection tends to pull the tool out of the cut. When parting from the front toolpost, which is less rigid, deflection pulls the tool into the cut and tilts it to the left, both of which tend to cause jamming.
                      #530462
                      Tony Pratt 1
                        @tonypratt1
                        Old mart, I like your sturdy rear toolpost design, better by far than some of the flimsy 'designs' I have seen!
                        Tony
                        #530464
                        Ady1
                          @ady1
                          upside down rear post is the best and simplest solution
                          #530467
                          Hopper
                            @hopper
                            The Boxford 280 has a camlock chuck so parting off in reverse with a front mounted parting tool would be easiest. You can buy side-mount holders for parting blades that would then be clamped in the regular QC holder. Otherwise you might have to buy a QC holder made specifically to hold a parting blade. Use carriage lock to prevent lifting while parting.
                            Edited By Hopper on 27/02/2021 08:55:20
                            #530542
                            Howard Lewis
                              @howardlewis46836
                              Rear toolpost and inverted parting off blade gets my vote.
                              IF a rear post can be fitted, it is safe for lathes with screw on chucks and without securing dogs.
                              Works so well, that I am now brave enough to part off under power, with a fine feed..
                              Keep the tool overhang to a minimum, so that rigidity is maximised. having things that flex is ma recipe for problems.
                              #530554
                              old mart
                                @oldmart
                                _igp2497.jpgSome more pics of my effort, the top part turns round to make use of both 26mm and 32mm industrial blades. I have blades 1.6mm, 2mm,3mm, 4mm and 6mm. The larger ones are too big to use for parting on the Smart & Brown model A, but could be useful for grooving. I also added a rear saddle lock to complement the front one to make sure the rigidity id not compromised by the upward forces. An advantage of inverted parting is that the swarf falls away better.
                                Edited By old mart on 27/02/2021 15:39:12
                                #530556
                                Chris V
                                  @chrisv
                                  David George, just sent you a PM.
                                  Chris.
                                  #530818
                                  Andy Sproule
                                    @andysproule22368
                                    Thanks for all the replies tried to drill the underside of the tool holder drills including cobalt hardly marked it.
