Inteference Fit
Inteference Fit
  • #185459
    Alan Rawlins
      @alanrawlins60482
      I want to machine a small ring of steel to fit a small 30mm outside diameter, ball bearing into it. I want to make sure that the outer ring of the bearing doesn't revolve when in use.
      How much smaller should I turn the inside diameter of the ring relative to the bearing outside diameter without decreasing the internal clearance of the bearing so much that the bearing locks up, but still doesn't revolve in the ring?
      #32473
      Alan Rawlins
        @alanrawlins60482
        Ball Bearing
        #185465
        Eric Cox
          @ericcox50497
          You need to machine the diameter a few thou 0.002"  larger than the bearing then use Loctite "bearing fit" to secure the bearing
          Edited By Eric Cox on 04/04/2015 08:55:52
          #185468
          Capstan Speaking
            @capstanspeaking95294
            I second Eric. A spacer ring is not rigid enough to resist an interference fit. It will simply swell up slightly.
            An old craftsman will assess interference fits as push fit, drive fit or press fit. However a bearing fit is usually sufficient at 0.0002" / 0.005mm interference.
            #185478
            mechman48
              @mechman48
              Do you have a 'Zeus' book handy…it gives you a listing of 'fits' for different sizes holes & shafts.. look in the transition fits..you would be in the region of H7/g6 for your needs… if you don't want to use Eric's Loctite method.
              George
