Injectors
Injectors
Home Forums General Questions Injectors
  • #25304
    Scrumpy
      @scrumpy
      Scrumpy
        @scrumpy
        my brother is coming to the plumbing stage of his 4-1/2 Burrell traction engine he has been told that he needs a 16oz injector I find this wrong as on my 3 in Marshall is fitted a 18oz one what are others using for there Burrell or Marshall thanks
        #302734
        Anonymous
          The start of this thread (before the gloves came off) shows you how to estimate the injector size for a given engine:
          #302741
          julian atkins
            @julianatkins58923
            You will not notice any appreciable difference between a 16 oz per min injector and an 18 oz per min injector. And what is the stated delivery rate is often different!
            Cheers, Julian
            #302917
            Scrumpy
              @scrumpy
              Many thanks for your replies on this subject I most enjoyed reading the link until someone took us in a different direction so it's out with the calculator to determine what to use , thanks
