Inherited Problems
Inherited Problems
Home Forums Manual machine tools Inherited Problems
Viewing 25 posts - 1 through 25 (of 33 total)
  • #174218
    David Watson 3
      @davidwatson3
      Amongst the workshop equipment I inherited is a Saunders 1/2" bench drill. As good a drill it may be I want to change the chuck to key less. The original chuck key was missing and finding a 1/4" x 12 tooth key is proving difficult. I have tried to remove the chuck by unscrewing with no luck . Any clues please.
      I also inherited a set of 6mm lathe tools for the mini lathe. They have triangular replaceable inserts. Any ideas who stocks inserts for these tools as there are three tools with no inserts fitted.
      David Watson 3
        @davidwatson3
        Chuck Key / Lathe tool inserts
        #174219
        nigel jones 5
          @nigeljones5
          rdg sell the insert
          #174222
          Bikepete
            @bikepete
            The chuck is likely mounted on a taper, rather than a thread. Typically it'll be a Morse 2 socket in the spindle, into which an adaptor fits with a Jacobs taper on the other end to mount the chuck – see e.g. here. For removal of the adaptor from the spindle there may be provision for a drift to go in from the side of the quill, while for getting the chuck off the adaptor a set of wedges may be necessary – both as per e.g. here.
            Is it definitely 'Saunders' BTW? Not familiar with it and best google could see was a 'Sanders' as per this forum post. Might be helpful to post a picture of it and a close-up of the chuck/quill area for further advice.
            #174223
            frank brown
              @frankbrown22225
              Chucks normally have short stubby taper called JT2/3/4. So they are pulled out. As for the chuck key, I bought a replacement one for an old power tool from a builders merchant. They had a huge catalogue with the right one in. 1/4" seems to be popular, have you tried Machine Mart?, I tried to count the number of teeth in their online picture, could be 12 (or 11, or even 13?).
              Frank
              #174225
              David Watson 3
                @davidwatson3
                Thanks folks. I had a look on the other forum and that is the same drill. The taper fit and wedges seems to be the way to remove the chuck. I will have a delve into the boxes from dads workshop I recall a wedge shaped bit of black steel. Maybe that's the missing bits.
                #174229
                Ian S C
                  @iansc
                  If the quill has a slot in it a few inches from the end A wedge shaped bit of steel 3" or 4" long fits in here to drive out a Morse taper. Otherwise the idea is a pair of flat steel wedges with a U cut out to go round the taper between the chuck, and the quill.
                  I too had a look for Saunders, couldn't find anything.
                  Ian S C
                  #174241
                  Bazyle
                    @bazyle
                    If there is no slot as mentioned by Ian and no hole down from the top it is likely that there is no morse taper hole but the spindle is solid and fits directly into the chuck. The chuck itself still probably fits on a taper it is just that you will have more difficulty to identify the taper sixe.
                    #174405
                    Ian S C
                      @iansc
                      There is usually a gap between the top of the chuck, and the bottom of the quill, in that gap you will see the diameter of the top of the taper, you will then know which size of taper wedge to get from one of the engineering suppliers, Warco, Arceuro Trade, or similar. Anyone who sells drill chucks, and machines to put them on.
                      Ian S C
                      #174406
                        Hi David,
                        Are you sure its 12 teeth? Most keys are 11.
                        My big Wolf drill has an 11 by 1/4" (0.242&quot key. You might find that one of those fits?
                        David Watson 3
                          @davidwatson3
                          This drill is a bit of an odd ball . I have had a close look at the chuck and it has" Rexon RJ 6-13 engraved on it. The chuck key is 1/4 x 12 teeth which is an odd one. I don't think the drill was used much whilst my father was making clocks, I recall him complaining about the key very early on. Most of his drilling was done on a Pots sensitive drill with a rising table rather than a quill like a normal drill. I remember it being made in the early 60,s and I still find it better for small drills. I have a cordless drill with a keyless chuck and find that be so much better than faffing about looking for lost keys so that will be a gift to my workshop next.
                          #174479
                          Chris Trice
                            @christrice43267
                            It may be possible to remove the chuck by drilling and threading a small hole inside the main body of the chuck and using an allen screw to jack the chuck directly off the taper. There's a good chance the body is not overly hardened and there should be a small gap between the end of the taper and the chuck body.
                            #174480
                              Posted by David Watson 3 on 02/01/2015 19:28:27:
                              David,
                              It might be worth trying here.
                              David Watson 3
                                @davidwatson3
                                Thanks for all the advise regarding the chuck key issues. I have had to admit defeat and get the chuck off. I am about to order another chuck but I am not sure what the taper is ?. As some one said the chuck is on a short tapered stub, JT2/3/4 was mentioned. I am going for a keyless chuck this time.
                                #177196
                                mechman48
                                  @mechman48
                                  I did the same with my metalworker bench drill.. got two wedges… size JT2
                                  & popped the original chuck off, replaced with keyless chuck, saves a lot of hassle looking for chuck key.
                                  George
                                  #177201
                                    If it isn't too old it may have a B-taper, if the small end of an MT2 taper fits it, it's B2 and so on.
                                    David Watson 3
                                      @davidwatson3
                                      A little more information regarding the taper for the chuck. I found a list of tapers on the ARC web site. The nearest I can get is JT 6. Could this relate to the RJ6-13 stamped on the body of the chuck?. The 13 I assume relates to the capacity of the chuck.
                                      #177209
                                        David,
                                        If you look at the link I posted previously and click on any of the chuck images, you will see that they identify the taper as B16 … [whatever that might be]
                                        Edit: corrected typo
                                        Edit: found the dimensions, here
                                        Edited By Michael Gilligan on 24/01/2015 20:43:01
                                        Edited By Michael Gilligan on 24/01/2015 20:46:04
                                        #177211
                                          This could help:
                                          Jacob's Tapers
                                          Taper Small End Big End Length
                                          mm inch mm inch mm inch
                                          #0 5.80 0.2284 6.35 0.2500 11.11 0.4375
                                          #1 8.47 0.3334 9.75 0.3840 16.67 0.6563
                                          #2 12.39 0.4876 14.20 0.5590 22.23 0.8750
                                          #2 Short 12.39 0.4876 13.94 0.5488 19.05 0.7500
                                          #2 12 15.88 0.625 17.20 0.677 26.80 1.055
                                          #3 18.95 0.7461 20.60 0.8110 30.96 1.2188
                                          #4 26.34 1.0372 28.55 1.1240 42.07 1.6563
                                          #5 33.43 1.3161 35.89 1.4130 47.63 1.8750
                                          #6 15.85 0.6241 17.17 0.6760 25.40 1.0000
                                          #33 14.23 0.5604 15.85 0.6240 25.40
                                          1.0000
                                          Creative commons share alike licence, from : **LINK**
                                          #177224
                                            From the link on my previous post:
                                            B16
                                            15,733mm
                                            0.6194"
                                            14,5mm
                                            0.5709"
                                            24mm
                                            0.9449"
                                            0.6165
                                            Go Compare ?
                                            Ian S C
                                              @iansc
                                              MichaelG, and Noel, you'v gone off wandering under the adds on the RH side.
                                              Ian S C
                                              #177240
                                              Les Jones 1
                                                @lesjones1
                                                Hi David,
                                                I am a bit confused about the problem. You seem to be talking about ordering a chuck but I can not see any post to say that you have removed the old chuck to measure the taper. I would have thought that you would need to measure the taper BEFORE ordering a chuck.
                                                Les.
                                                #177241
                                                  Posted by Ian S C on 25/01/2015 08:26:50:
                                                  Ian S C
                                                  Please Sir … it woz him wot started it !!
                                                  #177247
                                                  Circlip
                                                    @circlip
                                                    Posted by Michael Gilligan on 25/01/2015 08:43:35:
                                                    Ian S C
                                                    Same old same old, more than three years now and the basic web site problem still not rectified. Same as post numbers, or lack thereof.
                                                    Regards Ian.
                                                    Edited By Circlip on 25/01/2015 09:27:27
                                                    #177287
                                                    David Watson 3
                                                      @davidwatson3
                                                      Hi Folks, Thanks for all the information regarding the taper for this chuck. The nearest I can find to match the drill is JT6. As I said the chuck has RJ6 scribed on it this seems to be my best clue. After a bit of cleaning up I realise I was wrong with the make..The data plate on the side of the head say J Sanders, 1982, not Saunders as I first thought. The bench grinder that came from my fathers workshop is the same make. I have ordered a keyless chuck from Chronos this afternoon so I hope its correct.
