Indexable ML7 tailstock
Home Forums Manual machine tools Indexable ML7 tailstock
  • #13406
    AJW
      @ajw
      AJW
        @ajw
        Visited Ally Pally on Sunday, thoroughly enjoyed it and one of my purchases was a secondhand Myford indexed leadscrew wheel/handle.
        The indexed ring from this has now been fitted to my tailstock handwheel. Back of handwheel shallow bored to locate the ring which was stuck on with araldite along with a push fitted zero point on the tailstock casting.
        Only been fitted a couple of days but already finding it so useful!
        Before this I would generally hold a Vernier against moving parts to gauge depth.
        Can’t post pictures but some photos are in my Lathe mods album if anyone is interested.
        Alan
        #392913
        Philip Rowe
          @philiprowe13116
          Nice job there Alan, bit of luck you finding that handwheel I can't say that I have ever seen one before. Were they a standard Myford part or is it a homebrew?
          Phil
          #392930
          ega
            @ega
            It isn't a leadscrew handwheel by any chance?
            Easy to post from your album using the image button.
            #392935
            Malcolm Jones 1
              @malcolmjones1
              it isn't an Lavis vernier dial for the saddle hand wheel by any chance.
              I have one I removed from my old non power cross feed super 7.
              it will not fit the power cross feed super 7 that I have now.
              Just found the fitting instructions it was made by
              J T Lavis
              15 Goddington Road
              Bourne End
              Bucks
              Malcolm
              Edited By Malcolm Jones 1 on 25/01/2019 13:25:53
              #392951
              ega
                @ega
                The Lavis dial was divided into 86 and 1/4 divisions so I don't think it's this dial.
                #392988
                AJW
                  @ajw
                  Phil, my original tailstock handwheel has been modified by adding the engraved ‘ring’ part from an original Myford leadscrew handwheel.
                  I also, a while ago, modified my original non engraved leadscrew handwheel by fitting the ring from yet another leadscrew handwheel! This one was not a Myford part (so didn’t feel so guilty carving it up!) and isn’t engraved it looks laser marked.
                  When machining the parts for this one I made the indexed ring able to rotate independent of the handwheel so it can be zeroed or moved as required.
                  Once again a very useful mod.
                  I have just put a photo of the leadscrew handwheel in my lathe mods album.
                  Alan.
                  It’s not possible to put photos up from my phone, and boy I have tried!
                  Edited By AJW on 25/01/2019 17:19:41
                  Edited By AJW on 25/01/2019 17:20:12
                  Edited By AJW on 25/01/2019 17:20:53
                  #392990
                  ega
                    @ega
                    Posted by AJW on 25/01/2019 17:18:14:
                    It's not possible to put photos up from my phone, and boy I have tried!
                    Sorry if my comment touched a sore spot!
                    My impression is that many members access and post from mobiles so this seems a rather basic problem which deserves some attention.
                    #392995
                    Howard Lewis
                      @howardlewis46836
                      86.25 divisions sounds odd! Almost as if intended for one of the 12 tpi leadscrews on the ML 1, 2,3 or 4.
                      My old ML 7 came with a Picador Handwheel on the Leadscrew, so I took it into work one Saturday morning and used the optical dividing head inn the Standards Room to graduate it with 125 divisions. Was quite a useful modification.
                      Graduated Handwheels always come in handy, at some time or another
                      #392997
                      ega
                        @ega
                        Posted by Howard Lewis on 25/01/2019 17:47:40:
                        Agreed. Here is the Lavis advert:
                        No doubt someone can "do the maths"!
                        Edit: Malcolm Jones, might you post the instructions?
                        Edited By ega on 25/01/2019 18:21:15
                        #393005
                        Howard Lewis
                          @howardlewis46836
                          The secret is using the vernier scale to produce a result in sensible units!
                          #393013
                          AJW
                            @ajw
                            Well I’ve never seen one of those before!
                            What a good idea – not sure about the Vernier bit!
                            Might have to get hold of yet another handwheel!
                            Alan
                            #393020
                            Georgineer
                              @georgineer
                              It does sound odd, especially since 12 tpi gives 83 and 1/3 thou per rev.
                              George
                              #393031
                                Posted by Georgineer on 25/01/2019 19:19:48:
                                George
                                Dividing the dial into 86.25 divisions made more sense after I spotted that 8⅝" is 8.625
