in line oil check valve
Home Forums General Questions in line oil check valve
  • #806435
    Garry Coles
      @garrycoles69390
      Hi,
      The loco I’m building has piston valves and each piston valve cylinder has two oil points. If I come out of the mechanical lubricator with one 1/8″ pipe and into a Tee piece with two outlets of 1/16″ pipe into the piston valve cylinders will this be acceptable lubrication. And will I need an in-line oil check valve.
      Thanks
      Garry
      noel shelley
        @noelshelley55608
        The viscosity of steam oil is thick, a 1/16″ pipe may prove restrictive. Just a thought. Noel.
        #806470
        MichaelR
          @michaelr
          I would think a 1/16″ bore pipe would feed to the valves OK, and yes you will need a check valve in your 1/8″ pipe between pump and the Tee piece to stop any blow back that might occur.
          MichaelR
          #806486
          Speedy Builder5
            @speedybuilder5
            My lubricator has a check valve built into the oil pump cylinder. The delivery from the pump feeds two cylinders with piston valves however the oil is fed into the steam delivery pipes adjacent to the piston valves. Seems to work OK for me.
            Bob
            #806496
            salatipa
            Blocked
              @salatipa
              Yes, your configuration with a 1/8″ hose to a Tee and then two 1/16″ outlets can work, as long as the flow remains balanced. Personally, I would add an in-line check valve to avoid oil returns and guarantee constant lubrication. It is a simple but effective security.
