Thanks for the input:
Howard – that is exactly what I did – below are my results.
These are the readings from my metric clocks on each of the screws. (x-x) = dial division movement followed by the clock reading (mm).
Top Slide: (0-5) = 0.24; (0-10)=0.54; (0-15)=0.76; (0-20)=0.99; (0-25)=1.25
Tail Stock: (0-5)=0.23; (0-10)=0.49; (0-15)=0.75; (0-20)=1.02; (0-25)=1.25
Cross Slide: (0-5)=0.25; (0-10)=0.49; (0-15)=0.75; (0-20)=0.99; (0-25)=1.23
Lead Screw: (0-5)=0.3; (0-10)=0.59; (0-15)=0.92; (0-20)=1.28; (0.25)=1.60
These readings were repeated at least twice and in both directions as I was also trying to measure bashlash. As you can see the lead screw is the odd one out.
