ignition of i/c engine
Home › Forums › Help and Assistance! (Offered or Wanted) › ignition of i/c engine
  • #33863
    bricky
      @bricky
      #553790
      bricky
        @bricky
        I have finished the Rockerthump engine by Brian Rupnow and would like suggestions as to the ignition before TDC.The engine is single cylinder and has a 1.375 cylinder .
        Frank
        #553793
          Can't you ask Brian on one of the forums he frequents, I'm sure he will say what his is set at and maybe suggest he adds a note to the drawings.
          Failing that I usually find about 5deg BTDC works but most of my engines I incorporate a means to advance and retard the timing so it can be tweaked as needed, I quite like a slow lumpy tickover on some which needs timing differently to an engine built for speed and power.
          #553834
          bricky
            @bricky
            Thank you for reply Jason ,Brian should be up now so I will send him an e-mail .
            Frank
