Identifying Spur Gears
Home Forums Beginners questions Identifying Spur Gears
Viewing 15 posts - 1 through 15 (of 15 total)
  • #7383
    ChrisH
      @chrish
      ChrisH
        @chrish
        I have a bag of assorted small spur gears, some steel, some fibre, up to about 1.25in od and up to ½in bore. But whilst I can count the teeth I have no idea of how to identify them any further.
        Can anyone tell me how to identify them please, what to check, etc?
        Chris
        #170685
          If they are metric, divide the diameter in mm by (number of teeth+2) to get the module.
          If imperial, divide (number of teeth+2) by diameter in inches to get the Diametric Pitch.
          If you have meshing gears they should give consistent results (allowing for errors in measuring outside diameter, especially on gears with an odd number of teeth).
          Note that gears can be undersize and some metric and imperial sizes are very close (25 dp is near to 1 mod, for example).
          Rather harder to check things like the tooth angle, except by comparison with known gears.
          Edited By Neil Wyatt on 25/11/2014 17:52:38
          #170686
          Les Jones 1
            @lesjones1
            Hi Chris,
            There was a very good article in MEW 158 (December 2009) on making gears.This details most of the formula to do with gears. If you use the relationship between the number of teeth and the tooth tip diameter you should be able to work out the modulus or DP value. I used this to identify modulus 1 gears in assorted boxes of gears at model engineering exhibitions to get some more gears to use for screw cutting a greater range of threads.
            Les.
            #170707
            ChrisH
              @chrish
              Hi, thanks Neil and Les. With your help and reference to MEW 158 have managed to determine my little gears are DP 36 and with a PA of 14.5degrees so far, so well on the way with them. Thanks to you both,
              Chris
              #170716
              Jeff Dayman
                @jeffdayman43397
                Hi Neil,
                Just FYI the correct term is diametral pitch, not diametric pitch, for inch size gears. May as well get the nomenclature correct.
                Ready now for the usual mass accusations of anorak-ness and pedantry.
                Cheers JD
                #170723
                Martin Kyte
                  @martinkyte99762
                  Should that be Anorakal-ness?
                  :0)
                  Martin
                  #170724
                  mick
                    @mick65121
                    A friend of mine once described to me a particularly boring lecture on a hot summers day while on day release course at the local college, where he fell asleep. When, on being woken by the lecturer and asked, "well, what is a spur gear then lad?" his quick witted replied was, "the one you've got left over sir!
                    #170731
                    Ian S C
                      @iansc
                      A year or so ago someone produced a series of silhouettes of each gear, I can't find it, put in "gears" in the search panel, and you get 3 pages of threads.
                      Ian S C
                      #170749
                      martin ranson 1
                        @martinranson1
                        Contact HPC gears, they used to be called Hinchcliffe Precision Components, they have a wonderful catalogue with thousands of gears in it. Both Imperial and metric, all you need to do is measure your gears and compare with theirs. There are many charts of the different sizes available. The staff are extremely helpful. Hope this is some use. Martin R.
                        #170751
                          Posted by Jeff Dayman on 26/11/2014 00:36:21:
                          Hi Neil,
                          Jeff,
                          In times when even the O.E.D. is letting us down; it's good to see you trying to preserve the English language.
                          Ian P
                            @ianp
                            Posted by martin ranson on 26/11/2014 17:38:20:
                            Another feature of the HPC catalogue is that it has silhouette outlines of all the gear teeth profiles.
                            Google for 'HPCGEARS' and you should find their website.
                            Ian P
                            #170761
                              The Davall Stock Gears catalogue is good too.
                              The OED reflects English as she is spoke, not as she should be!
                              And as far as diametric/diametral – neither of them is in the OED anyway! Colllins (which always gives more useful definitions (rather than origins, IMHO) than the OED) says diametral is a less common word ffor diametric.
                                Posted by Neil Wyatt on 26/11/2014 21:39:16:
                                Oh … what's this ?
                                  Hmm, not in the non-subscriber online OED as far as I could see, though.
