How do I make a steam operated valve?
Home Forums Beginners questions How do I make a steam operated valve?
  • #245519
    nigel jones 5
      @nigeljones5
      I have made 4 x steam operated cylinder valves and a lever which in one position supplies steam and in the other position vents the pressure line to air. Its essentially two discs rotating against each other with an airway machined into one.My problem is that it leaks from between the two halves, even when a lot of pressure is applied. I machined them with power cross feed, sharp tool, slow setting. So how do I stop it leaking? Some form of lapping operation perhaps?
      nigel jones 5
        @nigeljones5
        #245528
        John Reese
          @johnreese12848
          Fizzy,
          Lapping is necessary. You can lap them individually on a flat lapping plate or lap one against the other. Even when lapped you are going to need enough pressure holding the plates together to resist internal pressure. It requires a very fine finish to make a reliable face to face seal.
          MW
            @mw27036
            Unless you can obtain a mirror finish on the surface i'd be doubtful if even that would seal it. You would be needing a perfect meet. As this is essentially a rotating joint it makes the situation so much harder.
            Michael W
            #245556
            nigel jones 5
              @nigeljones5
              have any of you achieved this level of seal? It doesn't leak much as is but its only a machine finish. Any suggestions as to lapping compound or grade? Thanks
              #245557
              John Rudd
                @johnrudd16576
                Depends on the material the discs are made from….?? Mild steel, brass, titanium??
                Start with coarse grade carborundum paste, finishing with jewellers rouge……somewhere in between these two ought to suffice maybe in stages starting with a less coarse to carbo, to something a little more aggressive than rouge
                #245563
                  Might be worth looking up LBSC's description of makling his 'disc in tube' regulator?
                    Just a thought [blissfully unaware of the size you are working to] … Could the ceramic disc valve from a domestic water tap be adapted do the job ?
                    julian atkins
                      @julianatkins58923
                      Hi Nigel,
                      Rotate with brasso (wet – dont let it dry out), and only in the movement that the valve operates. Check with micrometers blue.
                      I have made some fiddly bits over the years and the above procedure has always worked fine for me.
                      Cheers,
                      Julian
                      #245588
                      Maurice Cox 1
                        @mauricecox1
                        You could try relieving the area immediately around the pivot pin to allow the parts to bed together more easily, similar to my recent post to the chap who was making an oscillating steam engine.
                        Regards Maurice
                        #245593
                        Simon Collier
                          @simoncollier74340
                          The next one I make will have concentric o-rings either side of the port slot/holes. The one I had made, just faced, worked well for ages but then started to leak and got worse. Attempts to face or lap it failed and I scrapped it.
                          Edited By Simon Collier 1 on 06/07/2016 00:07:18
                          #245602
                          Anthony Kendall
                            @anthonykendall53479
                            Posted by Neil Wyatt on 05/07/2016 20:30:56:Might be worth looking up LBSC's description of makling his 'disc in tube' regulator? Neil.
                            Good old LBSC was a great user of good old pumice powder, then available in different grades.
                            Unlikely you will find it in the local Wilko methinks.
                            Edit – loads of it on eBay – but probably stick to what Julian says?
                            Edited By Anthony Kendall on 06/07/2016 09:19:15
                            #245628
                              Posted by Anthony Kendall on 06/07/2016 09:15:52:
                              You're right, they are sold out of pumice stones, easy enough to make our own powder from one
                              http://www.wilko.com/accessories-and-tools/wilko-pumice-stone/invt/0125906
                              As Julian says Brasso is a good gentle polish its abrasive is sodium silicate, Astonish is more aggressive and probably more like pumice (Astonish contains quartz as well as sodium silicate, both commonly found in pumice), especially good for stainless steel (I have cleaned more than my fair share of burnt pans).
                              Rik Shaw
                                @rikshaw
                                I keep a tube of Solvol Autosol in the workshop for lapping and honing and wet it with Brasso where necessary.
                                Rik
                                #245643
                                Bob Youldon
                                  @bobyouldon45599
                                  Hello Fizzy,
                                  For lapping I'd suggest a product called Timesaver, take a look at http://www.newmantools.com/lapping/time.htm I've never had a problem using it, it does what it says on the tin! I also keep a tin of Ajax scouring powder, always useful in the workshop. It always helps if you use dissimilar materials for each face, e.g.. phosphor bronze or monel disc on a gunmetal face; yet another idea, a chap on another forum is insetting the disc faces with a PTFE insert,
                                  Bob Youldon
                                  #245739
                                  Maurice Cox 1
                                    @mauricecox1
                                    Hi Fizzy,
                                    further to my post about relieving the area round the pivot; if you are lapping the faces on abrasive paper, make sure that the paper is held really flat on a genuinely flat surface; I use the ground base of my Fobco drill. Then, when you are doing the lapping, move the work in a figure of eight motion with even presure on it. After about six or eight stokes, turn the work through ninety degrees and repeat. Keep doing this and you should get a flat surface. If you just go back and forth, or in circles, this is similar to what mirror grinders do for telescopes. Not the shape that you want at all!
                                    #246274
                                    nigel jones 5
                                      @nigeljones5
                                      Ive tried anf failed with relieving and brasso, it was much improved but still leaked. So what alternatives are there? I see 3 way valves on ebay but im loathed to buy one. They are cnc machined at high speed and I simply cannot emulate that speed or accuracy. This is the last snag to my loco being complete! PTFE or derlin perhaps?
                                      #246317
                                      nigel jones 5
                                        @nigeljones5
                                        9o
                                        #246338
                                          Posted by fizzy on 12/07/2016 00:07:57:
                                          9o
                                          Does that ^^^ represent some noise made by your Avatar?
                                          … Are you trying to communicate ?
                                          #246408
                                          nigel jones 5
                                            @nigeljones5
                                            my avatar has just explained that daddy is not her best friend! Doesnt help my valve though!
                                            #246412
                                              Posted by Michael Gilligan on 05/07/2016 20:53:25:
                                              Ceramic disc was a serious suggestion.
                                              Mention of domestic water tap was meant as a 'ferinstance'
                                              julian atkins
                                                @julianatkins58923
                                                PTFE discs would be a better and simpler solution with steam, if other metal to metal methods have not proved ok.
                                                Cheers,
                                                Julian
