The Holbrook spindle has two parallel registers, one in front of the thread and one behind. Unique with the 1 3/4" BSF thread so no chance of finding a new, commercially made, one. Very unlikely to find a second hand one as these machines were rare, being very expensive new. Even if you do find a used one it may well not fit. It is said that Holbrook fitted backplates individually to each spindle.
You will need to make an accurate dummy spindle for final turning / fitting and, probably, an accurate pair of size gauges for the registers first. You can do the registers by measurement but final fitting gauges generally make it easier to get it right. Sounds the long way round but I've found that properly setting up with a dummy spindle end makes the job go far faster even with ordinary threaded spindles. Never done a Holbrook one tho'.
Best to have practice run on some spare material first. Although its fundamentally simple work getting it right needs concentration. The back register in particular being a pain if not approached correctly. I imagine the auto feed stop on the Holbrook will help if its still in good order.
Be highly tempted to make more than one backplate when set-up and in the groove.
PS I see Baz did his without a dummy spindle. Well done mate. Braver man than I.
Edited By Clive Foster on 21/10/2019 17:13:43
