Hofmann dividing head manual
Home Forums Help and Assistance! (Offered or Wanted) Hofmann dividing head manual
  • #288667
    Alexander Smith 1
      @alexandersmith1
      I've just bought a lovely Hofmann 4" centre height universal dividing head. It came with one plate and the gear banjo so I'm looking for a manual to identify the hole numbers for any other plates and any information on the gears normally supplied with it. The only source for a manual I've identified is METools online who sell a CD with the manuals for 4 or 5 different dividing heads including a Hofmann but they seem to have stopped trading.
      Any information gratefully received or, miracle of miracles, a source of plates or gears. Many thanks.
      Sandy
      Alexander Smith 1
        @alexandersmith1
        #288678
        Emgee
          @emgee
          Sandy
          Turn the plate over and you should find some more indexing numbers.
          Emgee
          #288684
          Ex contributor
            @mgnbuk
            Might be worth dropping an inquiring e-mail to Zeatz UK (used to be Zeatz Hofmann when I dealt with them at my previous employment) here : enquiries@zeatz.com
            Never know – might have something at the back of a filing cabinet !
            Nigel B
            #288690
            Bazyle
              @bazyle
              "I'm looking for a manual to identify the hole numbers for any other plates "
              It's not as difficult as needing a manual to identify the holes you are missing. All dividing heads use pretty much the same basic set up to 50 and the only variation is how many plates they use and which numbers are on which plate.
              A few examples:
              Brown and Sharpe 3 plates
              15 21 37
              16 23 39
              17 27 41
              18 29 43
              19 31 47
              20 33
              49
              #288692
              Bazyle
                @bazyle
                (new page 'cos it doesn't like too many tables at once)
                Elliott do it in 2 plates but go through the sequence on alternate plates
                15 16
                18 17
                20 19
                23 21
                27 29
                31 33
                37 39
                41 43
                47
                49
                #288695
                Bazyle
                  @bazyle
                  Some can replace a small number like 15 with say 30. It is really all about primes and multiples of primes. Above 50 most manufacturers supplied extra plates with more big primes which mostly nobody needed.
                  eg Elliott had 4 more (don't know why they threw in the 24)
                  24 53 57 59
                  51 63 67 69
                  61 73 77 79
                  71 83 87 89
                  81 93 97 99
                  91
                  #288703
                  Nigel McBurney 1
                    @nigelmcburney1
                    Hi I have the 4inch (100 mm) Hoffman head,with tailstock,banjo and a full set of gears for spiral or differential indexing, the dividing plate is double sided,after removing the index arms and the 3 c/sunk securing screws the plate can be jacked off its spindle by one of a pair of grubscrews,about m5 with slotted heads,you will then find on removing the plate there is a different pattern of holes on the other side.The two sides will cover most of the normal divisions required and further numbers can be achieved by differential indexing,including useful numbers like 127The one thing that it will not do,nor will most heads is combine spiral milling with differential indexing say to achieve a 127 helical gear,using Standard quipment.Indexing info and tables can be found in Machineries Handbook.I have never seen any ads for items such as backplates,or other spindle fittings I just have a 3 jaw chuck,and catch plate for between centre work..
                    #288719
                    John Stevenson 1
                      @johnstevenson1
                      METoolsonline was set up by my late wife, the much lamented Gert. Unfortunately when she died I shut the site down and also her Ebay account of Marypoppinsbag.
                      Hopefully later this year i hope to open the METoolsonline site again and I'm in the slow process of stocking up before it goes live again.
                      I do still have CD of the manuals she used to sell at £9.50 post paid to any UK address so if anyone wants one can they please drop me a PM.
                      In stock are the Dividing head CD, the Tool and cutter grinder CD, Bridgeport CD and the Shaper CD.
                      #288730
                      vintagengineer
                        @vintagengineer
                        I have a Hofmann and a set of gears but not sure if it is complete. I have 100,86,72,64,56,48,44,40,32,28, & 24 x2.
                        #288746
                        John Ockleshaw 1
                          @johnockleshaw1
                          Hello Sandy, I have a Hofmann UTH dividing head, the operating instructions and the tables for indirect, differential and spiral milling. The set of change gears is as listed by Vintagengineer above.
                          If you would like me to copy this information then send me your email address as a PM.
                          Regards, John
                          #288754
                          Anonymous
                            The list of change gears given is 'standard' for universal dividing heads; I have the same set for my Elliott dividing head.
                            #288758
                            Nigel McBurney 1
                              @nigelmcburney1
                              Last year searching for info on the Hofman head on the net I found that the later Hofman dividing heads had a hydraulic locking device for the spindle,and there were various threads on a US site that mentioned the hydraulic fluid was a special very expensive grease. Looking at my head I cannot see any way of even topping up the grease,via a screw plug or other device or even dismantling the lock. My spindle locks grip has deteriorated over the last 25 years and needs some attention,though from years of experience I have always found that though most mechanical items can be dismantled and renovated,when it comes to very precise devices they are best left undisturbed if possible ,back in the 1950s my old boss always believed that when installing machine tools make sure they are in the right place in the factory and bed them down and don't move them,they settle and then remain stable. Has anyone found out how to renovate the spindle lock?
                              #289683
                              Alexander Smith 1
                                @alexandersmith1
                                Just wanted to bring this one up to the top again so that I could thank all the people who contributed, sent me a copy of the manual or improved my knowledge of the basics of dividing head maths so that I might be able to work it out for myself next time. I don't know how we would manage without this site.
                                To answer Nigel McBurney's question above about the hydraulic spindle lock, the manual specifies BP HLP5 oil but I found another thread on this site (Dividing Head Help – Steve Garnett) where it was discussed and apparently any modern hydraulic oil with a viscosity of 32 will be OK – just need to find out where to put it now as it's not exactly clear from the manual.
                                Thanks also to the organisers of this marvellous site.
                                Sandy
                                #289709
                                  Posted by Alexander Smith 1 on 20/03/2017 17:16:58:
                                  The thanks belong with our marvellous contributors!
                                  SteveI
                                    @stevei
                                    Hi,
                                    I had some correspondence with Hofmman in Germany. Regarding the lubrication they told me and I quote:
                                    "use Klüberplex GE 11-680. Manufacturer is Klüber. You can also use other grease with similar specifications."
                                    I also asked about the spindle external taper on the UTH125. The internal taper is MT5 but the external looks like a American short taper D camlock type but it isn't. I did not get a clear answer. I've also asked Rotagrip as they sell a range of backing plates for chucks and they don't know either. The closest I've got is that it is according to some DIN specification but I can't seem to find that information at the moment. Does anyone know? I would very much like to order a backing plate, I'd prefer not to have to make one as face and taper needs to be really precise to work well.
                                    Steve
                                    #289919
                                    Alexander Smith 1
                                      @alexandersmith1
                                      There seems to be a bit of confusion here about the correct oil for the hydraulic spindle lock on the Hofmann dividing head.
                                      The one I have is quite old and is a type UTH. The manual I now have has a diagram which matched exactly the dividing head I have and it clearly states that the hydraulic spindle lock uses BP HLP 50 oil. The recommendation Steve has received for Hofmann is for Kluberplex GE 11-680 grease. I had a look online and this is a high pressure adhesive gear tooth lubricant. So one is an oil and the other is a grease and, from my admittedly very limited experience, I would not have thought they would do the same job, so either something has been lost in translation or we are talking about 2 different types of dividing head. Any thoughts, anyone? Could Hofmann in Germany have meant to use the grease for the external or internal gears rather than the spindle lock?
                                      Sandy
                                      #289957
                                      SteveI
                                        @stevei
                                        Sandy,
                                        Common sense suggest you must be correct. Mine is a UTH125 and I have no idea how old it is but I provided the S/N to Hofmann in my email. I have no idea if the design has changed over the years either. Perhaps my post was lacking in clarity, I asked Hofmann about all the lubrication specs and specifically the spindle lock and got that answer after 3 attempts. It was like pulling teeth. I never did get an answer about the spindle external taper instead only getting the answer that it was in the manual. I have not spotted the exact spec in the manual. Having said all that it is a very nice dividing head except when I am lifting it!
                                        Steve
                                        #336470
                                        Adam Harris
                                          @adamharris13683
                                          Sandy, my Hofmann UTH 100 sadly does not have its driven spindle that protrudes from the reverse side of the chuck and which is required for differential dividing (and also helical gear cutting). Would it be possible to describe this removeable spindle and how it is fixed? Adam
