High temperature soft solder flux
Home Forums Beginners questions High temperature soft solder flux
  • #244291
    ROBERT BLACKSHAW
      @robertblackshaw40066
      I am trying to soft solder brass to stainless steel with a high temperature plumbers solder. The problem is that it will not take to the stainless steel, I have took the oxide off the stainless so its clean,but I am using paste flux, the stuff for low temperature solder. Bakers fluid No 3 I have been informed is not the flux to use, any suggestions on this please
      #8182
      ROBERT BLACKSHAW
        #244295
          May depend on your specific solder but something like Stayclean Stainless flux should do the job, or carrs brown lable
          #244358
          Steven Vine
            @stevenvine79904
            During the great copper tube shortage late 70s early 80s we used stainless tube. We had to use an acid flux to solder up the brass and copper fittings. I guess you should be able to pick up a pot at a good heatingplumbers merchants.
