Help! Warco 220 leadscrew gears.
Home › Forums › Manual machine tools › Help! Warco 220 leadscrew gears.
  • #412650
    James Hounslow
      @jameshounslow14375
      I wondered if anyone either has a manual for this machine, or actually has this machine and can help.
      I have just acquired this lathe, and it is missing all the screwcutting gears, and also (the biggest problem) the gear between the 32 tooth on the spindle, and the lever action 'friction plate' disc to drive the lead screw.
      I can work out the screw cutting gears to make, but I am struggling with the tooth count on gear that is meshed with the spindle and would appreciate any help.
      There is an old thread regarding the warco 220, and I wonder if any of those with this machine are still active on this forum?..
      Many thanks
      James
      #13544
      James Hounslow
        @jameshounslow14375
        #412668
        Nicholas Farr
          @nicholasfarr14254
          Hi James, if you PM me an email address, I can send you a PDF of the manual.
          Regards Nick.
