Help needed with tiny numbers! – Sorted Thanks!
Home › Forums › Model Engineer & Workshop › Help needed with tiny numbers! – Sorted Thanks!
  • #492738
      I am struggling with reading the numbers on Item 7, page 39 of MEW issue 64.
      I suspect they are very tiny even on the original and haven't scanned well for the archive.
      I'm struggling to find my paper copy of issue 64 so can anyone send me a good scan of Item 7 please?
      Many thanks,
      [email protected]
      #38578
        peak4
          @peak4
          What format do you want Neil, pdf or jpg?
          Bill
          #492748
            Hi Bill,
            Either would be great, as long as I can read hose pesky little numbers!
            Thanks, at least one reader will be very grateful!
            peak4
              @peak4
              Neil, Check your mail, there should be something on its way.
              There is one particular number that's a problem, but let me know how you get on.
              Bill
              #492758
              EdH
                @edh
                If it's the dimensions for the diameter of the formers then they are all 0.187 different to each other so start with the largest at 1.500 and work downwards. I suspect the problem is with the 0.938 on the lower right hand side as the print has a mark across the 9 of 0.938.
                #492767
                  Thanks Folks,
                  I'm sorted now, many thanks to Bill and Keith.
                  It was mostly the former diameters, but none of them were legible at all, also the 0.938 isn't very clear even on a good scan.
                  At least one reader is going to be very grateful, and I#'m glad my time retyping the article hasn't been wasted!
