Some years ago, made a couple of replacement gears for a friend's ML3 (or was it a 4?) Used the same cutter as for gears for my ML7 .
My pal had damaged his gears by engaging Back Gear to lock the spindle while he clouted the chuck to unscrew it. The small amount of metal between the bore and the drive pin fractured, so DON 'T follow his example.
And the thread on the spindle nose is not the same as the ML7, it is smaller.
Edited By Howard Lewis on 23/12/2016 20:36:09
