Have you ever been here?
Home › Forums › The Tea Room › Have you ever been here?
  • #35504
    Blue Heeler
      @blueheeler
      #412853
      Blue Heeler
        @blueheeler
        You're doing a few hours on the lathe, everything is coming together and the parts are slowly building up and you're doing lots of different operations.
        Then all of a sudden the lathe isn't cutting right, you check everything and then everything once again. You start to think "What the hell has happened to the lathe"?
        You keep looking for what has happened and why you can't make a simple cut??????……and then you notice it.
        The motor is in reverse
        #412854
        not done it yet
          @notdoneityet
          Fairly obvious? Too tired?
          Mill does that as the VFD defaults in direction when the power is cut – simple solution is to set the vertical operation as default setting and the horizontal is easily spotted before trying to cut, if not changed over, as the cutter is running so much more slowly.
          #412873
          Mick B1
            @mickb1
            Yes, it still happens occasionally.
            Most of the screwcutting I do is Imperial on a Metric lathe, which means leaving the halfnuts engaged and reversing back to (start minus backlash) for each pass. Sometimes I'll realise I've reached the right depth after reversing out, and break down to start some other op without remembering to switch back to for'ard.
            But the symptons are pretty recognisable, and it doesn't generally fool me for more than a second or three these days.
            #412976
            Pete Rimmer
              @peterimmer30576
              Posted by not done it yet on 06/06/2019 05:23:51:
              An even simpler solution is to swap any two of the three phase wires to the motor. Then the default direction will be the direction you require.
              #412985
              AdrianR
                @adrianr18614
                Yeup yesterday, I was really puzzled why the auto feed was going away from the work.
                #413006
                Boiler Bri
                  @boilerbri
                  Yes too tired.
                  My bug bear once, was the tip being loose in the holder. It took me ages before i found it. Doh
                  Bri
                  #413875
                  Nigel Graham 2
                    @nigelgraham2
                    Tiredness is one of the main causes of simple mistakes.
                    Yet it's strange how the more experienced we are, the less we notice the simple and obvious when things go wrong; and instead look for the most abstruse / expensive / inconvenient solution first!
                    I am told by medics, medics are even worse. A few sniffles and a headache and it's death's door with agues, plagues and bad humours of the spleen; when all they've done is catch a cold.
                    #413884
                    Mick B1
                      @mickb1
                      Posted by Nigel Graham 2 on 12/06/2019 11:07:04:
                      Yes.
                      I blame Conan Doyle – you know, the old Sherlock Holmes quote: "Once you have eliminated the impossible, whatever remains, however improbable, must be the truth…"
                      So when confronted with a conundrum, the first thing you look for is the most impossible, in order to eliminate it first; and before you know it you've wasted ages eliminating the impossible before you even get to the plausible.
                      I sometimes used to find myself doing this when part of my job was bug-hunting in manufacturing planning software.
                      I reckon that idea's the worst possible way to investigate anything, and it's probably wasted more mental resource than all the broadsheets' crosswords. wink
                      Edited By Mick B1 on 12/06/2019 11:51:20
