Thought it was the training lathe I stand corrected thanks. Misleading with the TR standing for Tool Room. T is the Training Lathe have a mate with one.
Looks like theres two models ones an export AA both with similar gearbox as M300's. I don't have to change a change wheel just swap two over to cover smallest to largest threading with no rearrangement of other wheels. TR have to change a 24T for a 20T or similar so always have a spare change wheel.
Everything else about it same as M300 real good machines if older than 15 yrs.
There might be more info around on the Colchester Chipmaster equivalent made by same 600 Group sharing same parts, just make sure the variator is working or walk away.
Good ones of this calibre are increasing in value, so if used and unabused could be worth more than you pay for it in 5 years.
The only problem just check out its able to startup on mid variator setting in high speed then run it with a cut on using a convertor or inverter and make note of what it is.
Have a look around for what they are going for be prepared, I dropped on a bargain worked out at £750 6 yrs ago easily get £1500 now abused prices have risen.
Loading will be ok William its the spindle startup from zero and keeping it there when a cut is put on.
Like a car going uphill, need more throttle to attain same speed, more importantly motor runs through a pulley/gearing system so its like trying to pull away in 5th gear at fastest setting which requires loads more grunt perhaps three to four times the motor rating. Fairly sure will have to stop the spindle to select another speed range and limited to the RPM within that.
