In addition to Brian Wood's more knowledgeable advice, this is what i did, as advised by Geoff Halstead, to my BL12 -24.
1 Remove the bearing block for the Leadcsrew and feedshaft.
2 Rotate feefshaft until keyway is uppermost.
3 Disconnect leadcsrew and feedshaft (In my case this entailed driving out roll pins – Replaced by brass shear pins, drilled through to weaken them )
4 Remove feedshaft and leadscrew.
5 I removed, diagonally, two of the four capscrews holding the Apron to the Saddle, and fitted two lengths of studding, having fitted a nut to the top of each stud, the other capscrews were removed, and the nuts slackened to gradually lower the Apron from the Saddle.
Once down the studs were removed and the Apron lifted and put to one side.
If you need to remove the Saddle, you will probably find some "anti lift" blocks at front and rear of the Saddle.
If there are shims, note carefully where they are sited, and replace them, with their blocks, when reassembling.
HTH
