Grease/oil gun problem
Home › Forums › Workshop Tools and Tooling › Grease/oil gun problem
  • #241661
    richard 2
      @richard2
      I have acquired an Alemite 500 grease gun and am currently making a nozzle to fit Myford lathe nipples.
      My problem is that the end cap of the body is domed with two adjoining holes.
      As the cap is domed I cannot use a large washer and bolt to block them and they need to be oil-proof as the body will be full of oil; though not under pressure.
      In Guy Lautards(?) instructions the end cap of his gun was flat, not domed.
      Can someone tell me how to block these holes in the end cap. I am not up to making a new cap as it is 1.25" bore and with an internal thread I certainly could not cut.
      I have made Brian Forrests designed nozzle for Myfords and it works a treat.
      Oiling the lathe is now a pleasure, especially as I made the bit that does the job.
      Many thanks
      Richard.
      #18116
      richard 2
        @richard2
        Domed end cap
        #241755
        Gordon W
          @gordonw
          Assuming the two holes are the small breather holes- just solder them up, or I suppose jb weld or similar will do the job. Clean first of course.
          #241942
          richard 2
            @richard2
            Thanks Gordon
            The two holes were for the ram which is no longer required as oil does not need forcing into the pump.
            But I will take your advice and fill the holes with solder using a small piece of brass gauze as a base and will
            blanket tis will solder.
            Richard.
            #241951
            Dennis WA
              @denniswa
              Richard,
              You posted: "I have made Brian Forrests designed nozzle for Myfords and it works a treat."
              Where can I find details of this nozzle?
              Thanks
              Dennis
              #242037
              richard 2
                @richard2
                Denis,
                Brian Forrest's article "An Oiler for the Myford lathe"
                appeared in issue 178 p.46.
                Because my workmanship is of a minus standard I modified his design
                and made the body in three parts.
                Mine is made of ali as I have lots of it but I would have preferred brass if available.
                If you are anywhere near West Sussex you would be welcome to come and
                try my Reilang oil-can and see for yourself.
                Richard.
                #242038
                Douglas Johnston
                  @douglasjohnston98463
                  Hi Richard- I had the same problem a while ago and used JB Weld epoxy and that worked perfectly with no oil leaks after more than a year.
                  Doug
                  #242044
                  Dennis WA
                    @denniswa
                    Thank you Richard.
                    Despite their price, I use Reilang oil-cans. Like many other folk I have found them to be the best!
                    Dennis
                    #242081
                    richard 2
                      @richard2
                      Hi Doug,
                      Thanks for reply.
                      I have just ordered JB Weld epoxy and hope this will do the job.
                      Richard.
