Gauge Plate / spring steel
Home Forums Materials Gauge Plate / spring steel
  • #240520
    bullgoose
      @bullgoose
      Hi Folks.
      I would like to make a couple of old fashioned spring steel bands used to check brake shoe / cylinder operation on older cars with the drum off and need to find out what thickness will work the best and where to buy the material from.
      Does any member have experience of these devices.
      Thanks
      bullgoose
        @bullgoose
        Buying
        #240528
        Bazyle
          @bazyle
          I doubt it needs to be springy, just metal. Mild steel should do.
          #240530
          Dusty
            @dusty
            Gauge plate is not the material you need. Spring steel available in various thickness and widths from Reeves 2000 and I think other suppliers is the best option. Bazyle is right plain old mild steel is fine as you are only requiring resistance to the brake shoes expanding.
            #240531
              If you don't need to cover the whole width of the shoe then the metal pallet strapping may do, available at a skip near you.
              #240532
                Outsize jubilee clips?
                #240537
                Peter Krogh
                  @peterkrogh76576
                  A few wraps of wire always worked for me. C-clamps, big hose clamps (as Neil suggested), stout cord, etc..
                  Darn near anything will work. I've even torched the center disk out of an old brake drum….
                  Fun with cars…..
                  Pete
                  #240607
                  mechman48
                    @mechman48
                    Posted by Peter Krogh on 27/05/2016 17:34:40:
                    Fun with cars…..
                    Pete
                    IIRC last time I had anything to do with brakes was to have a block of wood against the piston wrapped in a couple of turns of wire & twist locked, when pressure applied to system the piston squeezed the wood, that showed the piston was free & also disclosed any leaks from the seals. That was many, many moons ago.
                    George.
                    #240611
                    Michael Cox 1
                      @michaelcox1
                      Posted by Neil Wyatt on 27/05/2016 16:53:12:
                      You can join Jubilee clips together to make really big ones.
                      #240619
                      not done it yet
                        @notdoneityet
                        I never bothered with anything fancy like that. Apply brake and try to turn wheel for single slaves and a piece of sticky label if I was ever unsure on both leading shoe set ups. Had self adjusters for the last 30 years and gave up on shoes at the front several years earlier (Fords). I wouldn't trust a modern day jubilee clip – most are not the same quality as years gone by….
                        But, as above, mild steel strips bolted together, or an old drum are two perfectly good solutions of several.
                        Edited By Richard Balderson on 28/05/2016 11:31:07
                      Home Forums Materials Topics
