Bacon Fat, saved from breakfast and SWMBO, (actually, you are doing both of you a favour) is a useful lubricant, especially for taps or dies.
If you are lucky, a gudgeon pin, (ideally new) from a diesel or petrol engine, will have the ends square to the O D. and so make a good Cylindrical Square. Otherwise, you may need to do some emery work, and a lot of checking, to produce the desired result.
Model Engineers, in particular, and other preservers of old machines (Steam, Vehicle, Motor Cycle etc) are likely to be the ones keeping alive skills which would otherwise be lost. (These range from reading an analogue measuring device, a vernier scale, drilling and tapping, blueing and scraping, and so on).
How many now know how to remove a bush from a blind hole?
Keep up the good work retaining useful legacies and techniques!
