Posted by Nicholas Farr on 03/08/2018 16:56:35:
Hi Richard, if it's a No. 2 it will be about 340 to 360 mm across the base and will weigh around 75 to 85 Kg. If however it's a No 5 it will be close on 500 mm across the base and will weigh 250 to 280 kg, this is assuming you have a standard flypress. In your thread that you were asking advice about a flypress, you said that you temporally bolted it to the floor and it ripped the bolts out and tumbled over. I'm a bit confused about that situation, as it should not have done that, unless, you have bought a bar flypress and you have left the bar out or it is missing and you are stamping metal which is sitting directly on the floor. A photo of your flypress may help us with a bit more advice.
Regards Nick.
Edited By Nicholas Farr on 03/08/2018 16:58:33
Thanks Nick. If you may have read above, I've now realised it's a #1 fly press. The smallest. In my defence, the #1 marking is half an inch tall and not very deep, on the ram, covered in crud – unless you know where to look, you won't see it.
Do you have any suggestions for temporary bolting it to the floor?
It had 3 holes for mounting, but my attempt didn't work well. I drilled through the concrete floor then drove 3 threaded rods in with loads of this adhesive, and attempted to bolt them down. I think it was this stuff or similar: https://www.diy.com/departments/evo-stik-serious-stuff-solvent-free-grab-adhesive-0-29l/212376_BQ.prd
It didn't topple the press over completely when using it, but when throwing the arm around it lifted it out of the ground slightly (10 degrees or so). So rather than it coming to a dead hault and throwing all that energy into the tool, it throws a load of energy every where else.
Does that make sense?
I need to be able to lock it down completely, somehow. I don't have the time or means to fabricate an entire frame right now, I just want it locked into the floor.
I have since had a more successful experiment – this time taking more of a swing with the arm to try and generate more force, just about getting a decent print (on a very flat surface). BUT it still just lifted out of the ground, so it isn't working to it's full potential yet.
I have a photo of the press somewhere, bear with me…
