Flat spring steel supplier.
Home Forums Materials Flat spring steel supplier.
  • #253599
    Mark P.
      @markp
      Morning all, can anyone point me in the direction of a supplier of flat spring steel? I'm looking for a piece about 600mm x 20mm x 2mm. I can find really thin stuff but none in the size I require.
      Thanks in advance. Mark P.
      Mark P.
        @markp
        #253601
        Gordon W
          @gordonw
          I don't know what it is for, but I have cut bits out of an old wood saw. Use a thin cutting disc in an angle grinder.
          #253605
          Mark P.
            @markp
            Thanks Gorden, never thought about that, I've got a few of those.
            Mark P.
            #253627
            jaCK Hobson
              @jackhobson50760
              It depends on the specific application but O1 (sometimes listed as ground flat stock or gauge plate) may well be perfectly suitable and you can get it all sorts of places in small amounts. 2mm would be quite a thick saw?
              I've got some CS70 if you can't find anything else. You usually have to buy that in very large quantities.
              #253640
              Gordon W
                @gordonw
                Just for interest, just measured an old saw and it's 2.1 mm thick. This is (was) a proper saw, 2 handed crosscut.
                #253643
                Mark P.
                  @markp
                  Well a saw it is then Gordon, thanks for the offer Jack. I've got a few old ones and they always turn up a boot fairs.
                  Thanks Mark P.
                  #253644
                    Reeves list 3/4" x 13swg (2.3mm) in 2ft lengths which is annealed for easy working.
                    #253648
                    Mark C
                      @markc
                      You could probably find some in the edge of an old mattress – it will be very high quality spring steel as it has to take an edge bend after it was made.
                      Mark
                      #253661
                      jaCK Hobson
                        @jackhobson50760
                        Posted by Gordon W on 02/09/2016 14:20:33:
                        I guess I was thinking of the throw-away hardpoints. Circular saw blades are thick as well and should be good for springs. TCT blades may be a gamble.
                        Beware some sources of second hand metal – it can have fatigue cracks that you can't see. Back of an old hand saw should be completely safe though.
                        #253684
                          @mike89748
                          If you have a proper gunsmith in your area (rather than a gun salesman) ask him where he gets his steel for making v-springs. Also, just a thought, but could you use a steel ruler?
                          #253689
                          roy entwistle
                            @royentwistle24699
                            Mike How many rules are 2mm thick ?
                            #253700
                            mark smith 20
                              @marksmith20
                              MK metals have 1" x 14g (2mm) x 1 metre .
                              Mark P.
                                @markp
                                Thanks for the replies,MK Metals looks like a good bet cheaper than Reeves.
                                Thanks again Mark P.
                                #253717
                                Chris Gunn
                                  @chrisgunn36534
                                  Mark, I have some 16G, which equates to 1.5mm if that is any good to you.
                                  Chris Gunn
                                  #253722
                                  Mark P.
                                    @markp
                                    Thanks for the offer Chris, I will get some from MK Metals as they can supply 1/8″x3/4″ which will do the job I need.
                                    Regards Mark P.
                                    #253743
                                    Mark C
                                      @markc
                                      I was not kidding about mattress edge strip, I used to work at a spot that made the stuff and it was quite demanding to make. The other thing we made (among a lot of other products) was "bra stay wire" which is used for – support in women's under wired bra's. It may be useful to remember that they have wire in them as this is also very high quality material. The stay wire is often oval in shape and coated in plastic but also to be found in round edged flats. They are usually in the range of a couple of mm wide by a mm or so thick (with the plastic coating removed.
                                      Mark
                                    Home Forums Materials Topics
