first IC engine
first IC engine
Home › Forums › Beginners questions › first IC engine
  • #250050
    John gallo
      @johngallo38006
      Hi, I am a novice ME. I have been teaching myself with the help of this and other great forums. The only thing I have built so far is the Stuart beam engine. It runs well so this is more or less my skill level.
      I am thinking of building a simple IC engine and am looking for recommendations for a first try. If it came with plans and some machining advice all the better. I am thinking of the booklet that came with the Stuart beam.
      I have a South Bend 9 inch lathe and a Uni- Vertical bench top mill to work with. If any one knows of a place I could find plans and possibly castings for a good first attempt IC model I would greatly appreciate hearing from you.
      Thanks in advance, John.
      #8241
      John gallo
        @johngallo38006
        #250053
        steamdave
          @steamdave
          A very popular first IC engine is the Webster 4 stroke. No castings needed. Download the drawings from John Tom.
          http://www.john-tom.com/
          Plenty of build logs over on HMEM
          http://www.homemodelenginemachinist.com
          Other possibilities are from the pen of Jan Ridders. Have a look at his site (it will probably come up in Dutch, but there is a button to go to English). His engines are also bar stock.
          http://heetgasmodelbouw.ridders.nu/
          The Emerald Isle
          #250145
          Ian S C
            @iansc
            Have a look on Model engine maker, there is a new little vertical IC motor there with plans, I'm thinking either it or the Webster.
            Ian S C
