feed speed
feed speed
Home › Forums › Beginners questions › feed speed
Viewing 25 posts - 1 through 25 (of 32 total)
  • #248605
    Sam Longley 1
      @samlongley1
      Yesterday I was doing my first "proper" milling operation on my warco mill. To insert a 3mm wide groove in an aluminium cover plate for an O ring. Plate was mounted on a rotary table
      I was using a virgin 3mm HSS end cutter obtained from Warco when I bought the mill. I was rotating the table by hand & not applying much pressure. Depth of cut 1mm, speed was 1125 RPM which is max for the bottom range on the M16 mill- it had not occurred to me to switch to top range
      after 1 inch of cut the cutter broke !!!
      Was 1mm too much for a 3mm cutter? was I running too slow? are Warco cutters carp? I am sure I was not applying much pressure.Was I using the wrong sort of cutter? Was I just unlucky?
      Any comments as to why I may have broken the cutter. There does not seem to have been a build up of aluminium on the cutter teeth when examined through a magnifying glass
      Thanks
      #8230
      Sam Longley 1
        @samlongley1
        #248616
        Ady1
          @ady1
          3mm or less is "watchmaker territory" and you will need to use a lot more care
          Weird stuff happens, drills snap in the middle of making a a hole etc etc, a tiny bit of swarf in the wrong place at the wrong time and "click.." your tooling breaks
          Higher speeds are usually better but I'm not familiar enough with teeny processes to say definitively
          #248620
            1mm deep with a decent 3mm cutter in Ali should be OK though for now you would do better to stick to the 1/4 times diameter as your max so 0.75mm depth.
            You say an "end cutter" by which I will assume end mill or 4 flute cutter. Really for slots you want a two flute cutter or 3 flute as a compromise. Not only will the 2-flute give a more accurate flute width it will also clear the swarf better which may well by why you snapped the cutter.
            What grade of aluminium were you milling and did you use any lubricant?. Some grades can be soft and sticky which will build up on the cutter and cause problems. This can be helped with a cutting fluid, on Ali use paraffin or WD40
            Sets of cheap cutters can be of variable quality
            Higher speed would help.
            #248624
            Ady1
              @ady1
              If I was doing a lot of teeny work I would find a way of "shortening" a drill or mill to its minimum, to maximise stiffness. like putting the milling cutter all the way in to the chuck and just leaving 3mm protruding kinda thing.
              #248627
              Ajohnw
                @ajohnw51620
                The aluminium may have melted a bit and stuck to the cutter, 'it happens. Also with that sort of size of cutter any looseness in the set up, slides etc can cause problems.
                Plus as Jason mentioned a slot drill would be a better option than an end mill.
                I usually work on a max depth = the diameter of the cutter but a fine feed is needed and I doubt if I would use that on a cutter under 6mm dia – that's end mills too. Slot drills have less flutes so would need an even finer feed or a much shallower cut. Jason's rule is safer.
                Ajohnw
                  @ajohnw51620
                  I have used plain old suds on aluminium but not at home. It's not to bad and might be a better option for people who don't want to sniff various oil fumes. I've used it for surface grinding aluminium as well.
                  It works 'cause water has a boiling point of 100C which is well below the melting point of aluminium so can carry heat away. Just like cutting oil it can be applied with a brush but was pumped when I have used it.
                  Muzzer
                    @muzzer
                    Make sure the x and y slides (and the quill) are locked and also slightly nip up the table lock so that there is no backlash. Use plenty of WD40 etc to prevent swarf sticking to the tool, make sure the swarf is cleared from the slot – and calculate speeds and feeds using something like FSWizard. It's also critical to feed consistently to prevent overloading the tool.
                    #248691
                    Sam Longley 1
                      @samlongley1
                      Posted by JasonB on 30/07/2016 10:11:21:
                      Yes I meant a 4 flute end mill
                      However, if an end mill will not cut a slot then what does one actually do with an end mill?
                      ie If I cannot cut a 3mm slot with my 3 mm cutter & need a 2 flute slot cutting bit, then what would I use my 3mm end mill for ?
                      Sorry if this sounds a bit silly but !!!!!!
                      #248695
                      Thor 🇳🇴
                        @thor
                        Hi Sam,
                        Difference between end mills and slot drills and their use were discussed here. You also mention in your first post running at 1125 RPM, that is quite a bit slower than I use on aluminium alloys. Have you tried using the top range of your milling machine?
                        Thor
                        Edited By Thor on 30/07/2016 18:18:45
                        #248699
                        Sam Longley 1
                          @samlongley1
                          Posted by Thor on 30/07/2016 18:16:11:
                          Hi Sam,
                          Thor
                          Well I might do when I get another cutter !!!!frown
                          #248704
                            Use a bit of paraffin or neat cutting oil and it will help stop chip welding, a major cause of cutter death.
                            You can salvage the end mill by grinding the end at an angle to give it one cutting corner. It's not as good but it may get you out of a hole some time.
                            Ajohnw
                              @ajohnw51620
                              Posted by Neil Wyatt on 30/07/2016 19:17:14:
                              One of the odd thngs about kerosene / paraffin and aluminium is that the term more volatile is often used to explain the advantage. It's also a weak lubricant. Bit more oily than petrol but a lot less likely to burn but the vapours burn easily.
                              Boiling point 2 to 300C, water 100C, The soluble oils – a lubricant. I'd guess this is why toolrooms etc use suds on aluminium. The thermal conductivity of water is also nearly 3 times higher.
                              Basically I reckon it's an old wive's tale that offers dubious advantages over other coolant / lubrication methods.
                              1L of some soluble oils will make between 10 and 40L of suds. Rather a lot of cans of wd40 and more efficient in several respects.
                              This one gives mixing ratio's.
                              Sam Longley 1
                                @samlongley1
                                I used water based lubs years ago on a Colchester lathe I had for very occasional use in my business. This caused rust build up & was a real issue. Modern ones may have changed, but if not, then I would prefer not to use them
                                #248736
                                John Reese
                                  @johnreese12848
                                  I figure the spindle speed should be 10,000 rpm for that cutter in aluminum. At the speed you are running you are probably exceeding the recommended feed per tooth on your end mill. A 2 flute cutter is best for aluminum. 4 flute cutters do not have enough chip space for aluminum. You can improve performance by using an end mill specifically designed for aluminum. It has polished flutes and a high helix angle in addition to greater chip space. Come type of cutting fluid is desirable to keep chips from sticking. I use soluble oil in a squirt bottle.
                                  #248740
                                  Ajohnw
                                    @ajohnw51620
                                    Posted by Sam Longley 1 on 30/07/2016 19:56:52:
                                    I've seen chucks in particular that get a brown patina due to suds but people should clean up their lathes and wipe over with oil fairly regularly and also try and keep it on the work not all over the machine. I've only been involved with suds at work and it doesn't seem to cause any problems there – the machines were generally looked after.
                                    I generally just use neat cutting oil from Morris Lubricants for problem jobs or if I want an exceptional finish. Just a smear via a lightly loaded kiddies paste brush. 5L of it will probably last longer than me.
                                    Having posted about suds though I have ordered a bottle but don't intend to flood things with it. I just suspect that it will be better for some things and again will just use a brush. When people see video's of pumps chucking out huge streams of the stuff it might be worth pointing out that even grinding doesn't need that high a flow rate.
                                    Edited By Ajohnw on 31/07/2016 00:50:20
                                    #248755
                                    frank brown
                                      @frankbrown22225
                                      My rough and ready cutting speeds are based on a 1/4" drill, 1000 RPM in mild steel. Ali or brass 2 or 3 times faster, other sizes pro rata. So 3mm (1/8&quot should be a minimum of 4,000 RPM.
                                      Frank
                                      #248790
                                      Ajohnw
                                        @ajohnw51620
                                        For milling I think this thread has gone a bit bonkers. I suspect Jason hit the nail on the head early on. The feed rate was too high for the speed the cutter was running at. There is no should be as far as cutting speed go other than problems can crop up of various sorts if it is too high. The type of problem will depend on the material that is being machined and the material the tool is made of. There is no too low really other than maybe chip breakers but in my opinion that is more related to feed rate.
                                        Also slot drills must be used when a milling cutter is plunged into something. End mills aren't very good at doing that – try drilling a hole with one. A slot drill will do that easily. End mills are for surface milling.
                                          Posted by Ajohnw on 31/07/2016 17:23:15:
                                          Exactly that ^^^
                                          It's the relationship between the two that's important.
                                          Ajohnw
                                            @ajohnw51620
                                            Posted by Michael Gilligan on 31/07/2016 17:49:19:
                                            Exactly that ^^^
                                            crying I have a feeling of despair every time the cutting speed thing comes up. People just wont realise that the quoted figures all relate to tool life – some one opinion of how long it should be and time to do a job and nothing else and that there can be all sorts of reasons for working well out of them.
                                            Maybe if they looked at old figures based on hardened tool steel cutters they would but I suspect that the myths would still persist.
                                            Edited By Ajohnw on 31/07/2016 18:05:05
                                            #248799
                                              Don't think I ever mentioned feed rate and mearly said speed was a bit slow for that size cutter.
                                              #248803
                                                Exactly that ^^^
                                                Given Jason's 'denial'… I will revise my response:
                                                [ I only included the reference to Jason as a courtesy ]
                                                Exactly that ^^^
                                                Ajohnw
                                                  @ajohnw51620
                                                  cheeky Doh – I got it wrong probably because I assumed Jason would mention that. It why a faster speed would help.
                                                    smiley
                                                    #249171
                                                    Howard Lewis
                                                      @howardlewis46836
                                                      On anther thread, (Power Feed to Milling Machine Table) I have, today, posted the figures given, in the late 1950s, by a manufacturer of Industrial Milling machines for the Feed per Tooth for various cutters, on low carbon steel. These figures (in Imperial units) are for Industrial machines and so should be drastically reduced for our less rigid hobby machines and fixtures.
                                                      For Aluminium, the figures would be roughly double those for low carbon steel.
                                                      For the example quoted, the Depth of Cut would be a MAXIMUM of 0.75mm (0.25 Cutter Diameter) and a Feed per Tooth of 0.05mm.  At 1125 rpm this should result in a feed rate of 225mm per minute for a four flute end Mill, obviously, a Slot Drill would be half of this. To me, this seems a bit much for a 3mm dia End Mill, which as we all know breaks quite easily!
                                                      Since the workpiece is Aluminium, kerosene would be the recommended lubricant. And without a pumped continuous supply, my suggestion would be to reduce the feed rate further, whilst dribbling on a supply from a squeeze bottle. The feel on the Handwheel, and the surface finish will give an indication of when you are overdoing things, hopefully before another cutter failure.
                                                      Howard.
                                                      Edited By Howard Lewis on 02/08/2016 23:54:23
